Micro 32 Problem at DVinfo.net
All Things Audio
Old April 2nd, 2005, 09:38 PM   #1
Guest
Posts: n/a
Micro 32 Problem
I have 2 Micro 32 systems... they've been great for weddings for over 2 years now... no problems. However, I have a transmitter problem with one set now all of a sudden. When close to the receiver, it's at full signal. When I get 20 feet away or more, I begin to get a weaker signal and even drop outs if the groom is moving around. My other unit doesn't do this and I tested the receiver with the 'good' transmitter with no problems. Has anyone else experienced a similar problem? What could be the issue... is something loose or broke (probably... I feel better when asking about this kind of stuff though:)
Any advice would be appreciated!
Old April 8th, 2005, 03:27 PM   #2
guessing...
Matt, I'm in no way an expert on the Micro 32's or UHF transmitters and receivers, but based on what you've described, I would guess that the antennae connection may be flakey or the antenna element may be broken.
Not sure if that helps you in any way. It may be best to send it into Samson for testing.
Michael
Michael A Westphal
Michael Westphal is offline   Reply With Quote
Old April 8th, 2005, 03:32 PM   #3
Guest
Posts: n/a
Yea, I pulled it apart and sure enough, the wire that was soddered from the antenna to the lead it was supposed to be soddered to was loose. I put some more sodder on it to refuse everything, and it works perfect now:)
