seperate audio from video at DVinfo.net
All Things Audio
Old September 16th, 2009, 01:46 AM   #1
Hello,
I have many DV material from which I only want to use the audio. So I want to seperate the audio from the video before I import it into Audicity. Is there a simple tool to do this. I know I can import the clips into an editor and then export audio only, but that is exactly what I want to avoid. Audicity will NOT import audio only!
Rob
Rob deJong is offline   Reply With Quote
Old September 16th, 2009, 09:44 AM   #2
You can use Adobe Audition. It will import just the audio from the video or you can try using the software below. I have used it and it worked for me. Hope that helps.
http://www.nch.com.au/switch/
Nicole
Nicole Hankerson is offline   Reply With Quote
Old September 16th, 2009, 11:07 PM   #3
Quicktime will save audio (that for which it has the right codecs) as aiff or wav files; mpegstreamclip (Squared 5 - MPEG Streamclip video converter for Mac and Windows) will also demux audio from a number of sources, including mpeg. Both freeware. / Battle Vaughan
Old September 18th, 2009, 01:20 AM   #4
Audio Converter Software. Convert sound files wav wma mp3 aac etc
Nicole
Thanks Nicole downloaded the software but which one to choose?
There's:
WavePad Audio Editor
RecordPad Sound Recordin
SoundTap Stream Recorder
Express Rip CD Ripper
Prism Video File Converter
Pixillion Image Converter
Old September 18th, 2009, 01:27 AM   #5
Quicktime has features as Export only on PRO version!
Old September 18th, 2009, 12:32 PM   #6
Rob is correct about QT Pro, worked with it for so long I sort of take it as granted...so it's not free, but extremely inexpensive and capable...thanks for the correction! / B Vaughan
Old September 18th, 2009, 07:33 PM   #7
There's:
You should be clicking on the link that says Download Switch for Windows or Mac. Those are just other software they offer. Have you figured it out yet?
http://www.nch.com.au/switch/switchsetup.exe
Nicole
Old September 19th, 2009, 12:03 AM   #8
I have downloaded Squared 5 - MPEG Streamclip video converter for Mac and Windows and am very happy with it. Does exactly and precisely and fast what I want it to do: seperate audio from vide. Didn't need even a blink into manuals or help. Good stuff. Thanks.
