xlr to minijack cable at DVinfo.net
All Things Audio
Old November 19th, 2004, 02:49 AM   #1
Hi
I have a Canon XM1/GL1 and a Sennheisser ME66/K6 set up.
I plan to get one cable made, with an XLR at one end and a mini jack at the other, to connect them.
Can this work well or do I need more kit?
Cheers
Ewan Mckerracher is offline   Reply With Quote
Old November 19th, 2004, 08:14 AM   #2
Well....in terms of a "kit" that isn't gonna begin to cover it, but it IS a necessary component. this is all you need to set up that mic, too, with that camera. Be sure you get a right angle on the 3.5 mm (mini) end to help act as a strain relief and keep the cable from poking way out on the side of the cam, the external mic input is flimsy as it is.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old November 19th, 2004, 10:00 AM   #3
Informative article
Check out this article by Jay Rose, which explains a lot of the details and recommends units.
David Yuen is offline   Reply With Quote
Old November 19th, 2004, 07:28 PM   #4
Re: xlr to minijack cable
<<<-- Originally posted by Ewan Mckerracher : Can this work well or do I need more kit? -->>>
Buy something to adjust your audio level.
Ivan Bernstein is offline   Reply With Quote
Old November 20th, 2004, 01:17 AM   #5
Ewan,
I use this set up myself. There are no problems, provided your connecting lead is short - mine is about 9 inches long. With long leads there is the risk of noise induction due to the microphone output being balanced and the camera input being unbalanced.
As Douglas said, get a R/angle 3.5mm jack if you can (Neutrik do these now), and also a R/angle XLR (Neutrik again) - the microphone is long enough without the extension of a straight XLR, also again there is the strain relief and accidental knock angle (sorry!).
The microphone is mono, and the camera input stereo, so you will have to either duplicate the L audio track during editing, or use a stereo plug, connecting the tip and ring together. I have done the latter and I am not aware of any impedance problems as a result.
If you do a search on this forum you will find details of the XLR pin connections in earlier threads.
Here in the UK, you can obtain Neutrik plugs and suitable cable from Composite Video
www.compositevideo.co.uk
Alan Craven is offline   Reply
