Sony releases WAV converter for HiMD at DVinfo.net
All Things Audio
Old November 2nd, 2004, 08:27 AM   #1
http://sonyelectronics.sonystyle.com/walkmanmc/wav.html
It specifies that only files made through the mic or line analog inputs can be converted. Whether or not this applies to files made with an AD converter through the optical inputs seems unclear to me.
Marco Leavitt is offline   Reply With Quote
Old November 2nd, 2004, 12:03 PM   #2
I believe this works on files created via optical port. I downloaded this, but don't have any optical devices here. What I do know is it won't pass files with DRM in the stream.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old November 2nd, 2004, 12:13 PM   #3
That would be very good news. Now if only there was Mac support!
Old November 3rd, 2004, 11:13 PM   #4
There has been a 3rd party .wav converter out for months: Marc's Hi-MD .wav converter. It does the same thing as the .wav converter (faster than realtime upload), does convert digital optical transfers (sony can only do analogue) and also it does not have an auto, non-disable-able 650mb auto file splitting as sony's does. If you are using this for video sync, having it auto split certainly doesn't make the process any easier. The one plus that sony has is that it does not have the possibility of glitching in the same way that Marc's does.
Sorry if I sound a bit biased, but sony really dropped the ball on this one and the minidisc community has picked up the slack. Check out http://forums.minidisc.org and you will find a download for Marc's utility in the Hi-MD section.
This is (both Marc's and Sony's fast converters), at least for the video oriented audio recording fans, a big reason to embrace hi-md as one of the cheapest higher quality recording mediums.
/end bias. (I love my NH900 -- it gets used everyday for lecture recording)
JVC DV3000U - 30P (non-interlaced) capture on a budget - tests@http://robvideo.netfirms.com
Rob Hester is offline   Reply
