Recording audio at 24 or 25 fps
I've been working with an Edirol R-44 mostly on short films during the last months. A few weeks ago I shoot a commercial, and after a few days the producer came back to me and asked If I had recorded the audio at 24 or 25 frames per second.
Honestly I didn't know what to answer because the R-44 has no time code capabilities. Now the question is: Is this a setting that really affects the sync between picture and sound? If so, how can I know if my R-44 records at 24 or 25 fps? All your help will be greatly appreciated!! Regards, Andres. |
#2 | |
Good news, Cousins! This week's chocolate ration is 15 grams! |
I agree with Steve, but why did the producer want to know exactly that?
Was their any actual film involved in your production or was it all completely on digital tape?. Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
Equal Opportunity Offender
Ditto again for the above.
Might as well let your producer know that you can do complimentary frame rate conversions on the audio at no extra charge for anything you are requested to record. Make yourself as useful as possible. :-P Andrew |
#5 | |
It was shoot on the Red One. Would it be different if it had been shoot on film?? Thanks. |
#6 |
Not without timecode that's associated with the audio.
#7 |
Very possible the producer assumes the audio is being recorded with timecode synched to the video... timecode that is generated by the Indi-sphere.
What kind of clapboard and slate are you using? |
#8 | |
what exactly do you mean by Indi-sphere? We were using a simple clapperboard, nothing digital involved, and no connections between camera and recorder. I'm also confused because of other job I did for a film school. There I worked with the Nagara V. We had no TimeCode connection between the camera (35 mm) and the Nagara, but they asked me to record the audio at 24 fps. I changed the setting to 24 fps but I think what it actually does is to define the format of TimeCode the Nagara will be receiving from an external source; is that correct? Thank you all for you answers. Regards, Andres. |
#9 | |
#10 | |
Thanks Steve, that is a great explanation, and it makes this point clear... now all I need to do is explain this to the producers :) While talking about this with an editor, I found that another reason why they ask this, is because when they import audio files in Avid they are prompted to select a TimeCode format. I guess that as Steve explained, that is just for positional reference. Thank you all for the help!!! Andres. |
#11 |
