Audio at a concert with a z1 - Page 2 at DVinfo.net
All Things Audio
Old September 16th, 2009, 03:51 AM   #16
Originally Posted by Marcus Martell View Post
Steve ,MAN YOU'r DEF da Man IN DA HOUSE!Thx a lot for your advices and help, but if u were in my shoes( is a speech we use in EU), if you have to record a concert from a central position(front of the stage), what shall you do)?Use the internal mic, setting it in auto?Or using the manual mode monitoring through headphones(as i always do) paying attention at the lines in the scale( that states -8(infinity) 40-30-20-10-0 red point) thst shouldn't go over?I guess 20-10 spot!I'm scared that if goes in auto the red point won't be touched but it will be clipped audio on the time line!
Thx a lot again
MM
I would never use the internal mic nor auto level control. Limiters yes, but level control on manual. Peaks should be hitting about -10 on the camera meters. How much freedom do you have in your micing decisions? Are you working with the band or the concert venue so you can coordinate a mic arrangment with them or are you on your own?
Old September 16th, 2009, 05:45 AM   #17
No not at all, pretty stars and pretty selfconsiderate band right here...i know that mtv factor destroys people but COME ON!
Marcus Martell is offline   Reply
