Meaning of "Balanced/Unbalanced" label at DVinfo.net
All Things Audio
Old August 20th, 2004, 05:59 PM   #1
Fred Retread
I know the difference between the two, but what does "Balanced/Unbalanced" mean when it's the label above a 1/4 " jack?
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old August 20th, 2004, 06:30 PM   #2
1/4 inch connectors can be balanced or unbalanced. If the cable is a TRS (Tip/Ring/Sleeve) connector, then it's potentially balanced, if converted from XLR/Cannon/Lo-Z connector, plugged into a balanced TRS connection. Just like an XLR/Cannon/Lo-Z cable/connector assembly carries 2 conductors and a shield, so can a TRS (Tip/Ring/Sleeve) which means it's effectively the same thing. Many years ago in Europe, many systems were connected via Tip/Ring/Sleeve instead of XLR. I think now most things are XLR.
Recording studios use TRS for patch bays in the form of TRS or TTL plugs, but it's fairly rare you'd occasion one in video production.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old August 20th, 2004, 06:49 PM   #3
It also implies that the equipment will automatically work correctly whether you plug in balanced or unbalanced to that connector.
For example on most Mackie mixers, all the 1/4" connectors except the insert jacks and the headphone jack can take either balanced or unbalanced connections.
Jay Massengill is offline   Reply With Quote
Old August 20th, 2004, 07:03 PM   #4
Fred Retread
Thanks, guys. And Jay, it was a Mackie I was talking about.
