Sony ECM 55 Lavalier Mic at DVinfo.net
All Things Audio
Old July 2nd, 2004, 09:47 AM   #1
Hi - I recently got hold of one of these mics not boxed, no instructions & no connector.
I'm familiar with audio recording and use a range of studio quality mics with & without phantom power (its Dv that I'm new too - thanks to this forum I've taken my first steps.. nothing fancy as yet).
Back to the question. I know that the Sony needs power and I've seen reference to a battery pack for it but can I simply wire an XLR to it and run it from the desk or my Di box (which has 48v Phantom Power) or will this fry it?
Here's hoping its that simple
Cris Linscott is offline   Reply With Quote
Old July 2nd, 2004, 12:19 PM   #2
The Sony ECM-55b we have has a amplifier body which takes a single AA battery.
If yours does not have this, I would then assume it will be okay to send
it 48v phantom.
Jacques Mersereau
University of Michigan-Video Studio Manager
Jacques Mersereau is offline   Reply With Quote
Old July 2nd, 2004, 02:01 PM   #3
Thanks Jacques - I'll be getting on with the soldering then.......
Old July 2nd, 2004, 02:40 PM   #4
The regular power supply for this mic contains other electronics, I wouldn't connect it directly to 48v power. I'd consult with someone from Lectrosonics. They could tell you how to properly wire the mic capsule directly to a low-powered supply like a transmitter input. They could also point you in the right direction for info on a full-powered adapter.
Jay Massengill is offline   Reply With Quote
Old July 3rd, 2004, 09:52 AM   #5
Yeah, I guess I whiffed here. What I should have said, if your ECM55b
does NOT have the amplifier body THAT TAKES A BATTERY, but DOES
still HAVE an amplifier body non the less, THEN its okay to hook up phantom.
I didn't realize that your mic went to a bare (cut) wire.
Have I got this picture right? Does your mic have any kind of connector?
Jacques Mersereau
Old July 3rd, 2004, 10:56 AM   #6
Jacques/Jay - I should have been more specific - I've done some more research following Jay's posting - The model is, in fact, a 55BPT - its unused and has approx 3 metres of cable leading from the capsule terminating in three tinned cut wires (one of which is sheathed red, the other thicker braided and the final a fine wire) - appreciate your help with this - normally I'd contact the manufacturers support section but Sony Professional products here in UK seemed to be hidden from all... finally tracked down to www.sonybiz.net but silence from that quarter - What do you think?
Old July 3rd, 2004, 11:36 AM   #7
Retired DV Info Net Almunus
Cris,
Sorry to get to this a tad late. I have two Sony ECM-55B's. I am sure I can scan the brochure and email it to you if you believe it would be helpful. Just let me know.
Old July 3rd, 2004, 12:54 PM   #8
Ken - thank you - that'd be real helpful - my first time with lavalier mics so everything helps!
Old July 3rd, 2004, 04:57 PM   #9
The two ECM-55b that we have both have amp bodies that take a single
AA battery.
Ken?
Jacques Mersereau
Old July 4th, 2004, 03:40 PM   #10
Yes, the 55B's have an inline module that takes one AA battery as a power source. However, I am not sure of its other functions. I've never tried to use the mics without this module.
Will dig-up the brochure asap. (Holiday doin's here right now.)
Old July 5th, 2004, 11:04 PM   #11
I haven't forgotten you, Cris.
Just had a rather busy holiday weekend. Will dig up the brochure Tuesday.
Old July 6th, 2004, 02:31 AM   #12
Ken - thanks, in your own time, hope it was a good holiday weekend - have had a reply from Sony.... ".. please contact your dealer for this information". Boy, wished I'd thought of that!
Old July 6th, 2004, 09:43 AM   #13
Check your email, Cris. I sent it to you this morning.
Old July 7th, 2004, 03:38 AM   #14
Ken - thanks very much for the brochure - I've been able to use it with a UK company who confirm that 55BPT relates to "pigtail" ie bare wiring, and that a Sony DC78 power supply is required (as others on the forum have noted). A Hirose type connector is used on the bare wires to connect to the power supply the output to the desk is then on an XLR. The 55BPT option is for those who already have such a supply. Thanks for the help and observations
