Inexpensive DAT replacement? at DVinfo.net
All Things Audio
Old May 3rd, 2004, 12:29 PM   #1
http://www.core-sound.com/HighResRecorderNews.html#NEWS
The information they post suggests this is nice. Douglass?
Mike Rehmus
Old May 3rd, 2004, 01:03 PM   #2
Whoa... very cool, but a bit overwhelming to fully take in, if one isn't already an audio wiz. How would a setup like this compare with using the Marantz PMD (as the post says, as a field DAT replacement) in terms of: a) ease of use; b) reliability (I've had compact flash cards fail); and c) the audio quality?
Marcia Janine Galles is offline   Reply With Quote
Old May 4th, 2004, 09:44 PM   #3
i actually have the mic2496, only i use it with an iRiver IHP-120. advantage of the iriver over ipod is... it has an optical input. the mic2496 has an optical output.
ihp-120 records 16 bit 48khz or 44.1 khz.
the sound is very very clean and stays sync with video
Josef Crow is offline   Reply With Quote
Old May 5th, 2004, 12:20 PM   #4
This is a newly developing recording platform. Currently, Core-Sound's hardware has only digital inputs. I know of one company (PocketRec.com) working on a software /hardware solution (part of which is from Core-Sound) that will take both stereo analog and digital inputs. The software will feature a full set of recording and editing tools. However, I would not consider it to be "inexpensive".
It will be available from ATSComms.com
Marty Atias is offline   Reply With Quote
Old May 5th, 2004, 09:37 PM   #5
Core-Sound appears to have analog input available.
$1,000 compared to a good dat is inexpensive I think.
Mike Rehmus
Old May 5th, 2004, 10:47 PM   #6
Corrected. With the Mic2496, it does have analog mic level inputs. I beleive that PocketRec is developing another A/D device as well with mic pre's and /or line level inputs.
According to Core's estimates, the hardware (assuming you find the PDA for only $150.00 - New would be closer to $500.00) will range from $800.00 to $1200.00. The various software packages range from under $50.00 to around $700.00
Not "inexpensive", yet no more expensive than a standard professinal MD, HDD, or CF recorder. Professional DAT recorders are now history.
Old May 6th, 2004, 01:10 PM   #7
<<i actually have the mic2496, only i use it with an iRiver IHP-120. advantage of the iriver over ipod is... it has an optical input. the mic2496 has an optical output.
Josef, where can you get the best price on the mic2496 and the toslink to miniplug optical cable. I have a ihp-120 also. (they now call it the h120).
Joe C.
Joe Carney is offline   Reply With Quote
Old May 6th, 2004, 01:29 PM   #8
1K compared to a good DAT is quite expensive. Core has some really cool stuff happening, i looked at it at CES, but it wasn't fully ready for launch then. PD Audio CF looks awesome. Then again, HiMD is looking pretty promising too.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old May 7th, 2004, 06:05 PM   #9
<<<-- Originally posted by Douglas Spotted Eagle : 1K compared to a good DAT is quite expensive. snip -->>>
But Douglass. Most DATs won't handle GPS, games, and email!
Mike Rehmus
