New Gitzo Carbon Fiber boompole at DVinfo.net
All Things Audio
Old April 21st, 2004, 03:31 PM   #1
Does anybody have the G-557C? I'm asking because it just arrived, and while I can't believe how much I love this thing, I was just curious why there's a small hole on the last extension piece, a little under the shock mount thread/screw. This doesn't have the ability to internally run cable, so why the hole? Is it a flaw or is it there for some reason?
Marcia
Marcia Janine Galles is offline   Reply With Quote
Old April 21st, 2004, 04:16 PM   #2
The hole is for the exit of an internal cable (before the connectors are attached of course). This pole is too small in diameter to feed already connected XLR's like some larger poles can.
Jay Massengill is offline   Reply With Quote
Old April 21st, 2004, 04:32 PM   #3
<<<-- Originally posted by Jay Massengill : The hole is for the exit of an internal cable (before the connectors are attached of course). This pole is too small in diameter to feed already connected XLR's like some larger poles can. -->>>
You mean an internal cable "from the factory," as in a pre-cabled version of this ? Didn't know it came any other way. Of course I may not be understanding what you mean, never having owned one before. What do you mean "before the connectors are attached? Sorry to be so clueless. In any event, at least it's not a flaw. That's all I was really wondering about. :-)
Old April 21st, 2004, 04:45 PM   #4
Marcia,
While the Gitzo's don't come with an internal cable, you could add one yourself. Only catch is you have to cut one end of you XLR cable off so you can thread it through the holes provided, then reattach the XLR end. Here is a quote from Gitzo's web site:
All Gitzo microphone fishpoles have telescopic extensions which are locked into place with convenient twist-lock system, allowing simple and efficient setting of the required boom length. Each pole comes complete with its own unique 1/4" - 3/8" reversible mounting screw, port hole for microphone cabling at both ends and soft rubber hand grip.
The "Port" hole they are talking about is what you're describing.
Rob Wilson is offline   Reply With Quote
Old April 21st, 2004, 04:56 PM   #5
Marcia, yeah I got mine a couple of months ago and I like this pole too. Dunno if you were like me but I used a painters pole before and well, you can guess the difference! The best thing I like about it is how small it goes. Good for tight spots and carrying around. My painters, was about 4metres at max extension but it was still 2 metres at it's shortest!
Aaron
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old April 21st, 2004, 05:44 PM   #6
Many thanks, Rob. I get it now. :-) And Aaron, yeah this thing is awesome. I've been lifting hand weights to increase my strength for an eight week shoot, and while I know holding anything up gets hard after awhile, this is far lighter than I dared hope. I like the easy twist extension locks, too.
Old April 29th, 2004, 08:53 PM   #7
Rextilleon
Congrats on your Gitzo--I like holding mind behind my back, parallel to the floor---(your height might be an issue here) but it reall works when you can use your shoulders to rest the boom on. Anyhow, enjoy your new toy.
David Mintzer is offline   Reply With Quote
Old April 30th, 2004, 12:15 AM   #8
Thanks for the tip, David. Will try that. I cut a piece of foam to wedge into my hat, to rest it on my head if I need, too, as the day drags on. Nice to have another option. Between those and my Boomate I just might survive. ;-)
Old April 30th, 2004, 07:59 AM   #9
When you need extra height, make sure you keep your arms straight up with a grip no wider than your shoulders. This is the least fatiguing position when you can't rest it on your shoulders.
It can also be helpful to add a small weight to the very end of the boom to shift the balance point closer to your hands. I sometimes use a collar from a barbell for this. It weighs about 8 extra ounces but greatly decreases the amount of leverage the boom has against you.
Also look for any weight you can shave off the mic end. Use phantom versus internal battery, use the minimum parts for the mic mount, substitute nylon fasteners instead of metal, run any transmitters at your belt instead of at the mic, etc.
