Thread Tools
Search this Thread
Soundbooth CS3: Too much static:
Hello,
I am working on narrating a video I made. The quality of the actual voice is good but there is too much static in the background. I am using PPCS3 and Soundbooth CS4. My recording level using the Samson COU1was set at 37 (vista) (Control Panel -> Sound->Record Level). The audio clips when I normalize them jump up to 10 to 13db. As you can imagine, when I render out the video, the static in the background for audio is a bit much. Fortunately, there is music in the background so it makes it listenable. I read some posts on this forum and it seems like I should NOT use normalize and audio gain to make my audio louder. If I do not add audio gain or normalize to the audio cilps, they are too quiet. What should I do then? I am a newbie to the audio world but fully understand I need to learn a lot to improve the situation. Any tips that could lead me in the right direction would be appreciated. Thanks, Simon |
#2 | |
ex. if your peaks are -5db and the average level is -10db then set the audio gain for +8db so as to keep the norm a bit less then the peak of 0db. If there is audible static then it is something in your hardware or mic settings that is causing it. |
I tried it and it worked!
Cool. Much better quality. Thanks! Simon |
