AKG Blueline has switch on mic at DVinfo.net
All Things Audio
Old May 16th, 2009, 10:35 AM   #1
I am working on getting my new Juicedlink and blueline with hyper module working well on my FX1. I am wondering which setting I should use on the microphone switch.
Any suggestions or explanations will be greatly appreciated.
Bill
Bill Wilson
PK Productions ~ From Mild to Wild Las Vegas, NV
William Wilson is offline   Reply With Quote
Old May 16th, 2009, 05:55 PM   #2
Itīs either a low cut filter you want to use to cut handling and/or wind noise or a -10db pad you use if you record something pretty loud that would otherwise overload your mic.
Matthias Krause is offline   Reply With Quote
Old May 18th, 2009, 09:50 AM   #3
In general, I'd say keep that low-cut engaged if you are recording dialog. You'd want to disengage it if you were recording music and had the mic on a mic stand.
Marco Leavitt is offline   Reply
