Octava mic test at DVinfo.net
All Things Audio
Old April 26th, 2009, 02:11 PM   #1
Octava mic test
An engineer told me this clip is not usable. Thought I'd get a second opinion here.
Old April 26th, 2009, 03:11 PM   #2
did he say why?
Sacha Rosen is offline   Reply With Quote
Old April 26th, 2009, 03:27 PM   #3
Peaking at -25db, yes that's too low, but when I brought it up the noise floor was OK.
Surely not the pinnacle of narration recording, but far from unusable... good enough for many purposes, I think. Good enough for you?
Old April 26th, 2009, 04:09 PM   #4
Originally Posted by Sacha Rosen View Post
did he say why?
He said the levels were too low.
Thanks Seth.
Old April 26th, 2009, 07:06 PM   #5
The editor probably could not get them loud enough via the NLE's volume controls and knows not how to normalize.
Old April 26th, 2009, 09:32 PM   #6
Is that what it takes to "Make it right"? Normalizing? If so, can it be done in Vegas?
Old April 26th, 2009, 11:00 PM   #7
Yes, which is what I did. Right-click on the audio clip in the timeline. Pull down to Switches, and select Normalize.
If you have additional clips that need the same setting, you can repeat the above - or - right click on the clip which has been adjusted, select Copy. Select all the other clips (via shift-click and/or ctrl-click) to receive this setting, right click on one of them, and pull down to Paste Event Attributes.
Old April 27th, 2009, 03:35 AM   #8
Aside from low levels it appears to be recorded at 32kHz instead of video standard 48. Not a disaster but not a good idea. IMHO, original source recordings should always be done at as high a quality as possible. There's a bit of squeaky sibilance so a touch of de-esser will be needed.
Old April 27th, 2009, 05:58 AM   #9
If this was submitted for broadcast, I would have rejected it as well.
A QC or broadcast engineer's responsibility is not to fix out of spec material.
Old April 27th, 2009, 09:53 AM   #10
Squeaky sibilance? is that background hiss?
About 32k, the camera menu says 48k. Maybe when I exported it to quicktime? I don't think the JVC can record at anything but 48k.
Brian Luce is offline   Reply
