Help with my plan for recording 4 performers! at DVinfo.net
All Things Audio
Old January 30th, 2004, 07:16 AM   #1
All:
Thanks for your advice:
Planning on recording 4 performers (sometimes only 2 or three) for an extensive multi-shoot production.
I have a Canon XL-1 with MA100.
I also have a Mackie 1202 mixer (with phantom power)
I plan to buy 4 Sennheiser Evolution 100 Series wireless mics (with transmitters and receivers).
My plan is to input the 4 mics into the mixer, and output from the 2 mixer "main output" channels to the 2 MA100 inputs.
I also have a Senn ME66 mic. I don't have the budget for a boom operator though.
Anything wrong with this picture? Suggestions? Thanks!
John Garth is offline   Reply With Quote
Old January 30th, 2004, 09:57 AM   #2
John,
Is everything fixed in place? Do the performers move? What are they performing, music or dialog or both?
You've got the gear, but more info is needed to help advise what you are asking, I think
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old January 30th, 2004, 12:52 PM   #3
Good Questions
The talent will be stationary, like a TV broadcast of "The View" and the audio will be dialog.
Appreciate your help!
Old January 30th, 2004, 09:42 PM   #4
If the talent is stationary, then you could save $2000 and have better sounding audio. Use Wired lavs. Take the extra money and buy a multitrack recorder. Mix the 4 seperate tracks in post, and you'll substantially lower your noise floor. Or you could spend the $2k on an automatic mixer. Same end result (lower noise floor than having 4 mics open all the time) and less time in post.
Martin Garrison is offline   Reply With Quote
Old January 30th, 2004, 11:24 PM   #5
And if you have a laptop, record straight to that, using a multitrack audio software like Audition, Vegas, Sonar on a PC, or Deck or ProTools Free on a Mac
Old January 31st, 2004, 05:46 AM   #6
wired mics and recorder
I like your suggestion about the wired mics. Plus I already have one Sony condenser mic, and would only need 3 more.
I will be setting up each shot. I'll only leave mics open as needed.
I have a Panasonic SV-3800 DAT recorder, but I think it only records 2 channels. Any advantage to recording to it from the mixer rather than going to the XL-1?
Stupid question: how do I sync audio from the DAT to the video in post, once both are captured in Media 100?
Old January 31st, 2004, 11:51 AM   #7
Without genlock, the easiest thing is to have someone clap their hands, use a clapboard, something that is on camera, that can be seen as a spike or transient in the audio waveform, and can be verified on the camera. If the mic's are within reasonable proximity to the noise source, you'll have sample accurate or near sample accurate sync after lining the waveforms up.
Douglas Spotted Eagle is offline   Reply
