Thread Tools
Search this Thread
Electrical humming and hissing noise
This might be a Z1 issue or a mic issue but hopefully you guys can help.
I've just picked up my camera with a sennheiser k6/me66 mic attached. I was hand holding it and in certain positions particularly if i tilt it slightly i get a noticable hum, like an electrical hum. i've tried it in a room with all the electrical stuff off and it still happens. i had a play with the audio levels and when i moved them way up the hum got louder but seemed stay there for a second or two even when i'd lowered it. it only stops if i move the mic off the camera via a longer xlr cable. there is also another issue with a hiss. but this happens on all my mics. i not sure if this is related but thought i should mention it. i get the hiss even when no mic is plugged in, but not sure if this is normal or not. Thanks |
I'm guessing here, but it sounds like a ground fault in either the xlr cable or the mike. Since it goes away when you use a different cable, that would be a good clue....
However, we once had a noisy ME66 that had a fault of some kind that Sennheiser repaired under warranty, it was more like intermittent static than a hum in that case. / Battle Vaughan/miamiherald.com video team |
i may have located the issue. I think its the position of the mic to the camera or its actual connection to the camera. even with the longer cable, when i attach the mic it gives this hum noise. not sure how i can get round this, i'm already using a rycote type clamp to keep the fluffy out of the lens. does this ring any bells with others? any way round it?
Hissing problem
You need to change your cable or your Gain setting is too hot.
