BEC mounting box at DVinfo.net
All Things Audio
Old March 15th, 2009, 07:25 AM   #1
BEC mounting box
Anybody use the BEC AT-1820?
BEC | AT-1820 Wireless Reciever | BEC-AT1820 | B&H Photo Video
Can't seem to find good pictures of it. What holds the wireless receiver in place? What's the bottom look like? Would I have easy access to the controls on the bottom of my AT dual receiver? There's switches and stuff down there. One thing I like about the stock AT receiver holder is the bottom has a velcro flap you can pull on and off, giving you quick access to the controls.
Marco Leavitt is offline   Reply With Quote
Old March 15th, 2009, 08:44 AM   #2
Marco,
I have these boxes for my Lectrosonics. The bottom has a metal tab to keep the receiver from falling out but is open otherwise so you can get cables into it. They usually require a bracket to attach to the camera and then you can add a second box to the outside of the first. Your access to controls will be limited when it is in the box but I don't know the AT so I it may not be a big deal. The lectro controls are on the top so it isn't too bad
Old March 15th, 2009, 09:17 AM   #3
Is there anything (other than gravity) actually holding the receiver in the box?
Old March 15th, 2009, 12:29 PM   #4
Marco,
If you turn it over than the only thing holding it in would be the cable connected to the camera. It is usually not a problem. You can always put some tape over the top if you are worried. On the other hand I had some one put in one of my receivers with some velcro on it and it was damn near impossible to get the unit out.
Old March 15th, 2009, 01:10 PM   #5
Just what I wanted to know! Thanks Daniel.
