Thread Tools
Search this Thread
#16 | |
Hey there folks.
So, this is the information I just got (Trew Audio was very helpful): Quote:
Home: See "Work" :) Work: Canon XH A1, CS3/CS4/CS5/Final Cut Studio/Final Cut Express/Premiere Elements |
#17 |
Thanks for the information! That Trew does the connector work is an excellent thing - a lack of time on my part has kept me from using the Sanken with my Sennheisers. This changes that.
#18 |
#19 |
Digital wireless translates the audio to a digital data stream in the transmitter and sends that to the receiver. Higher quality sound, not as subject to dropouts, no need for companding and its resulting noise, etc. For details take a look at the Zaxcom wireless on their site. Be prepared for extreme sticker shock <g>. Senn G2 will run about $600 for a transmitter/receiver pair. Zaxcom digital will run in the vicinity of $4000 for a xmtr/rcvr set.
Good news, Cousins! This week's chocolate ration is 15 grams! |
#20 |
Makes perfect sense. Thanks, Steve.
Looks like I won't be getting the "D" model after all. You guys just saved me $50. |
#21 |
Nate or Mickey:
Can you give an update on how the COS-11X/D worked out with your G2 system? What vendor did you end up using? Thanks, Jeff
Panasonic HMC150/Canon A1/JVC HD1/Sony Vegas 8.0c |
#22 |
I'm actually holding off on purchasing the wireless system since the Sennheiser G3 is so close to being released. But, I do have a COS-11x with an 1/8" mini-jack connection coming that I purchased directly from B&H. It's being drop-shipped directly from Sanken (they called to verify what type of wireless system I was going to use).
In the meantime, I'm hoping to use the mic wired directly to my H4n. Make some sort of belt for the recorder and use it directly instead of a wireless transmitter. Then I'll sync the audio in post. I'll let you know how things turn out. |
#23 | |
Im ordering a COS11D-EW-Black from B&H today along with a lot of other items for a shoot coming up in August. I wonder if the onboard power from my Sony PCM-D50 will power this mic? Any idea? Anyway, my EW100 G2 518-554 MHz sets are still working great until the FCC turns off these frequencies. Will the G3 use the same microphone connector?
#24 |
Hi Jeff!
Sorry, but I have yet to purchase COS. :( Sorry that I can not be of help. Cheers, Micky
#25 |
Jeff -
The G2 and G3 units use the same connections, so you should be fine when/if you switch over. As for plugging it into the PCM-D50, I'm not sure. I'm wondering the same thing myself for the H4n. Does anyone know if the COS-11D mics with 1/8" connectors will work plugged in directly to the Sony PCM-D50 or Zoom H4n? Can't speak for the PCM-D50, but the H4n has one 1/8" mic jack with the option for "plug-in" power. It also has combination 1/4" (line) / XLR (mic) inputs with optional phantom power. Are any of those connection types the same as what I'll be getting with a G3 wireless transmitter? Are there any connections that I should definitely avoid testing on this microphone? Thanks, -Nate |
#26 | |
The plug-in power from the Sony D50 will power the condenser mics with the G2/EW plugs. However, it does not seem to be made to do it, as when pushed all the way in you get the left channel. When the connecter slips out just a hair, it slips to a notch it wants to stay in, and both channels are fed after a loud pop (keep the level to 0 while connecting). On the D50 this would not be a feasible connection for real field recording due to no way to securely maintain it. However, it works great for tesing purposes. I used it to test the ME2 vs the COS11D lav mics and the G2 radio system vs direct recording to the D50.
#27 |
Plug-in power on the Zoom works to power this mic as well. The locking connector definitely is not the right fit to the 1/8th jack. However, I soldered my own adapter that is a locking female 1/8th jack to standard 1/8th male plug and it works great. The recording is mono (right channel only), but that's what I was expecting. I'm assuming the left channel is used to supply the power.
#28 |
Update on the COS11
Now that I have tested and used the COS11, I can offer some comments comparing it to the ME2.
1. The COS11 has a slightly lower noise floor than the ME2. 2. The COS is slightly more sensitive than the ME2. 3. The COS11 is much richer sounding with more low end than the ME2. If you thought the ME2 made people sound good, the COS11 does a much better job of it. The ME2 is definately thinner. This is not really a negative aspect, but the only thing I have noticed is that when you use one COS11 lav to pick up two people (wedding ceremony is an example) the non micd person sounds thinner than with the ME2, because with the ME2 both people sound more evenly thin in comparison to the COS11. You still have better sound overall with the COS11, but the difference in non micd speaker is clearer. Maybe I am describing a proximity effect, I dont know. The COS11 can handle more manipulation in post though, so that is good. Bottom line, for an upgrade to your ME2 lav, the COS11 is a good choice. It works great with the G2 radio system.
