iRiver E100 help at DVinfo.net
All Things Audio
Old February 10th, 2009, 06:29 PM   #1
iRiver E100 help
Hi everyone,
Could anyone help me out with choosing the correct lav for the iriver e100.I need it for back up audio at a wedding this coming Sunday.I have the sennheiser g2 kit....do those lavs work in a standard 3.5mm mic input? probably not but just figured I'd ask.Any suggestions would be fantastic.
Thanks! Ryan
www.rhmphotography.com What you talkin bout Willis?
Ryan Morey is offline   Reply With Quote
Old February 11th, 2009, 10:47 AM   #2
I've used my G2 mics (Tram, Countryman, Senn ME-2) without issue on Sharp minidisc recorders. So I would surmise it should work, providing the E100 provides plug-in power at the 1/8" input
Old February 11th, 2009, 11:19 AM   #3
Problem is some iRivers use very non-standard wiring of the extrnal input jack, which I don't remember right off the top of my head. Search Google to see if you can track it down.
Old February 11th, 2009, 11:24 AM   #4
Hey Ryan,
I use the Giant Squid for my iriver. Here's a write up about Irivers with suggested microphones for use
iRiver Recorder for Video Production
Noel Lising is offline   Reply With Quote
Old February 11th, 2009, 01:18 PM   #5
great ...thanks everyone.I had to get everything ordered today so I wound up buying an at-199 lave with a xlr 3 pin connector.Then I got an adpeter from the xlr to the 3.5mm input.I think that will work......hopefully.The guy at b+h helped me out.Are the countryman lavs pretty good? I want ot replace the lav that came with my g2 kit.It's a little thin if ya know what I mean.Thanks again for all of your help!
Ryan
Old February 11th, 2009, 04:51 PM   #6
Ryan
Countryman lavs are excellent, very high quality.
There may be a problem on your horizon. First is not all XLR->3.5mm cable adapters are wired correctly to begin with and second, the iRiver itself assigns non-standard functions to the tip, ring, and sleeve connections inside the jack. Not knowing exactly what you have, what's going to happen when you mix 'em together is anybody's guess. I mean, it won't explode but you may or may not hear any signal and if you do it may or may not sound any good.
Old February 11th, 2009, 06:29 PM   #7
Steve I wound up buying a yamaha POCKETRAK CX SD RECORDER.I wasn't sure I could trust the iriver.The guy at b+h said I should have no problems...but like you said I'll find out when I get it....wish me luck.
Thanks again,
Ryan
