recording audio with free run or rec run mode, how to get time code on daw (WAVELAB) at DVinfo.net
All Things Audio
Old February 7th, 2009, 09:38 AM   #1
HI I IMPORTED ON WAVELAB some audio files that i recorded on fostex pd6, i expected to read time code on wavelab, i recorded in 24h mode, and I supposed to find the time code track with the clock on the time line, but i found just the ABS time. did i miss something
David Aliperti is offline   Reply With Quote
Old February 7th, 2009, 10:12 AM   #2
AFIK, Wavelab doesn't read the BWF file timestamp. I find no mention that it does in the manual.
Old February 7th, 2009, 10:18 AM   #3
who reads? protools? i tryed with nuendo also.
Old February 7th, 2009, 10:39 AM   #4
Adobe Audition, Sony Vegas to name two. What6 are you trying to accomplish in an editing, mastering application like Wavelab where you need to have the file start timestamp aligned to the timeline?
Old February 7th, 2009, 11:16 AM   #5
what's the pourpose of manage with free run or 24 h run when what i see is that all editors use to synk audio to video just by slate or hand claps (in vry low budget short movies)
Old February 7th, 2009, 11:26 AM   #6
I'm not sure I understand what you're saying. Are you trying to align an audio file with a video that it's supposed to match? Do the audio and video files have identical timecode, where you've sent code from the camera to the recorder or vice versa? If they don't, there's no point anyway.
Old February 7th, 2009, 11:38 AM   #7
no there was no synced camera, at the moment I wanted only to figure out how a time code track could be readed, it was just an experiment, (sorry form my bad bad writing), i recorded some files in 24h mode on fostex pd6 and thought that whene i would have opened them with wavelab or nuendo i could have readed on timecode bar the time related at audio file but i readed only the abs time
Old February 7th, 2009, 12:07 PM   #8
i found this page related bwf and timecode
Working with BWF audio in FCP
Old February 7th, 2009, 12:48 PM   #9
Well, as you discovered, not all applications can read the BWF timestamp and automatically position the clip on the timeline based on it. Nuendo will import a clip so the file start is placed to align with the timeline playhead cursor. One workaround you might explore is to get a copy of a program called BWF Widget. It allows you to read the timecode in the file's header. Read the code and make a note of it, then go into your audio program, position the playhead cursor at the corresponding spot on the timeline, and import the audio file to the timeline.
Steve House is offline   Reply
