results from this setup
if i get some tax money back may get this setup. record direct into camera with a schoeps,sd 302 with headphones. Would directly into camera be a waste if i got decent equipment like the shoeps and sd?
Ive heard samples with the sd being used and it really made a difference. Going into camera will be much easier for me. (should specify it would go into a canon a1) Last edited by Mike Leah; January 18th, 2009 at 02:41 PM. |
#2 | |
well put another way -
I have a HD100. I've had the audio board replaced. At mic level, its noisy, at line level its clean. using an external mixer sending line to the camera nets me good-as-its-gonna-get sound without going into a separate audio recorder. so if your preamps are reasonably clean AND put out enough phantom power, you could do it to start with. down the road, having a mixer is more versatile when needing to add more mics, or feed 2-3 cams. another things is that when having low dialog levels, the mixer preamps will be cleaner then the cameras if you are really using the gain. so you could start with a great mic feeding the camera, then add the mixer down the road, or get a SD single or dual channel preamp which is cheaper, and might be enough for your needs for some time to come. of course don't forget a decent boom and lyra shock mount. |
You don't say which Schoeps but you are going in a good direction. FYI the SD302 going into the Canon at Line Level usually means running the Canon inputs wide open just to get to -20.
#5 |
thanks for all the replies. Most likely the cmit5u. Audio is a much greater challenge for me than shooting.
