reducing the hollow sound? at DVinfo.net
All Things Audio
Old December 15th, 2008, 08:11 AM   #1
I filmed in a hall and the sound is a little hollow, is there anything I can do now to reduce this effect and make it sound less amaturish?
Oh I have soundbooth and premiere CS4
--Canon XL1--
http://www.richardgrebby.co.uk
Richard Grebby is offline   Reply With Quote
Old December 15th, 2008, 10:46 AM   #2
I think this might be a situation to use the shoot it again filter.
Also you could try using an equalizer to take out some of the high end. There is no reduce echo filter though.
Edward Carlson is offline   Reply With Quote
Old December 15th, 2008, 03:29 PM   #3
I think Edward has the right answer ! However, as you mentioned "Hollow," you could try a graphic EQ & put in a dip 3 - 6dB. between about 400 - 800 Hz. It may help marginally but try experimenting around these points.
RonC.
Ron Cooper is offline   Reply With Quote
Old December 15th, 2008, 08:58 PM   #4
and remember in the future that when you hear it in the headphones again, do something about it then. :)
Regards,
Ty Ford
Ty Ford is offline   Reply
