MA100 or Beachtek? at DVinfo.net
All Things Audio
Old August 26th, 2003, 02:02 PM   #1
Slash Rules!
MA100 or Beachtek?
My MA100 is messed up again. I've had it repaired once, and I'd rather not do it again. The question is, do I get a new one, or get an equivalent beachtek XLR adapter? What are the big differences between these two? I know the Beachtek doesn't double as a shoulder pad, but that's not a big concern, seeing has how the MA100 barely doubles as a shoulder pad.
Old August 27th, 2003, 11:45 AM   #2
Re: MA100 or Beachtek?
<<<-- The question is, do I get a new one, or get an equivalent beachtek XLR adapter? What are the big differences between these two?>>>
I would highly recommend buying a beachtek DXA-6.
Reasons:
Phantom Power: DXA-6 yes, 2 channels - MA100 None
Variable gain control: DXA-6 Yes - MA100 No
Ability to take +4dBu line level input: DXA-6 Yes - MA100 No (distortion)
Ability to plug in 1/8" stereo mini input: DXA-6 Yes - MA100 No
Ground lift: DXA-6 Yes (two flavors) - MA100 No
Mono input, but can flip switch to record to 2 channels: DXA-6 Yes - MA100 No
I really like my Beachtek, the customer service is great
(I lost phantom on my old unit, they shipped a new model without prompting)
and the sound quality is very good. Jay Rose of DV mag agrees.
Jacques Mersereau
University of Michigan-Video Studio Manager
Jacques Mersereau is offline   Reply With Quote
Old August 27th, 2003, 12:40 PM   #3
Slash Rules!
That model you mentioned, is it the one for the XL1s?
Old August 27th, 2003, 01:08 PM   #4
I have an XL1, so my guess is that it should work perfectly. It has
a stereo mini output that plugs into the stereo mini part of the
XL1 mic's input (the other submini hole is for mic power).
If you want to use the RCA inputs, plug on an adapter.
Jacques Mersereau
Old August 30th, 2003, 11:33 PM   #5
Slash Rules!
Why is the DXA 6 substantially better than the DXA 4C, which is, in beachtek's words, made for the XL1?
Old August 31st, 2003, 08:47 AM   #6
Call Harry at Beachtek and talk with him. They are really nice people and will tell you everything you want to know. (Harry is the owner)
http://www.beachtek.com/company.html
Bryan Beasleigh is offline   Reply With Quote
Old September 2nd, 2003, 03:42 PM   #7
Slash Rules!
Talked to Harry. He said the advantage on the DXA 6 was simply the 48v phantom power. The beachtek, he claims, will have less hiss than a Canon XLR adapter.
THIS IS VERY IMPORTANT: Can you screw the DXA 4C beachtek adapter, should you so desire, into the hole on the tilted part of the XL1s? I've discovered that when handheld, it's much easier when the center of the camera is on your shoulder, and not the back of the camera. . .so I'd want to be able to attach the adapter to both holes.
Josh Bass is offline   Reply
