DIY Wind protector? at DVinfo.net
All Things Audio
Old November 8th, 2008, 03:24 PM   #1
DIY Wind protector?
I'll be recording sound for a short exterior scene tomorrow morning, and had it all figured out until I realised I didn't have a high wind protector available this time. It's saturday evening and the stores and rental places in Montreal that I tried contacting are all closed.
Wind is supposed to be 10-15km/h (about 6-10 mph), although the location is partially protected.
The mic I'm using is the Sanken CS1 short shotgun mic, and I have the black foam windscreen that comes with it, but I doubt it will do well on its own.
Is there any way to imitate a wind protector?
Wyatt Tessari is offline   Reply With Quote
Old November 8th, 2008, 05:31 PM   #2
To shoot in wind, you really need a full zeppelin, not just a slip-on windscreen. Anything you try to make from scratch with what is laying around the house is going to degrade the sound more than a zeppelin. You would have to craft something and run some tests to know if the loss of quality is acceptable for your needs and situation.
Can't think of anything you would have access to that would be even a poor imitation of a real zeppelin.
Sorry,
Dan
Old November 9th, 2008, 05:34 AM   #3
For small mics, a sieve is perfect at creating the still air space necessary.
I can only think of a couple of sieves and some plastic garden netting rolled over them to make a tube, covered with the leg cut from a new pair of the wife/girlfriend's tights.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old November 9th, 2008, 05:43 AM   #4
Originally Posted by John Willett View Post
... covered with the leg cut from a new pair of the wife/girlfriend's tights.
Or you can cut your windstopper underwear to pieces, cover the outer netting with the softer breathing material and use the windstopper material suspended inside the tube or vice wersa. High tech's low end - nonfurry windjammer.
T
Toenis Liivamaegi is offline   Reply With Quote
Old November 9th, 2008, 12:32 PM   #5
A bit of gutter screen from the hardware store, chopsticks, hair binders, some costume fur and wire to put it all together. I've instructions somewhere on here or around.
Index of /Images/blimp
Some images of the mic setup I've got...I've switched out the mic stand as a boom pole with a 12' extendable aluminum painters pole with a 3/8" flare male to 1/2" Pipe Female brass adaptor which puts the paint pole on thread with standard mic holders. The blimp is comprised of gutter screen cover (for keeping leaves out of the roof gutters) cut to length and wired together into a tube, chopsticks and rubberbands as a shock mount and an old mic holder wired into place. Cover with costume fur sock and you're good to go.
Web Youtube Facebook
Last edited by Cole McDonald; November 9th, 2008 at 12:39 PM. Reason: added more detail
Cole McDonald is offline   Reply
