Marantz PMD 660: has it been "fixed?" at DVinfo.net
All Things Audio
Old November 1st, 2008, 04:23 PM   #1
I just saw a glowing review of this recorder in a webinar about rish media boradcasting. A forum search here turned up very mixed reviews, many of which are a couple of years old.
Has this device been updated to fix the noisy pre-amp issue?
Was considering this as a double system device with a consumer camera (usually with a SD 302) and as a stand alone for shooting stills/interviewing people.
Thank you
Bob
Bob Kerner is offline   Reply With Quote
Old November 2nd, 2008, 12:04 PM   #2
"Has this device been updated to fix the noisy pre-amp issue?"
Not that I know of...
The 0dB XLR out of the 302 works with the 660's line-in without overdriving the 660's fixed frontend and sounds okay.
I've found internal mics to be useless. The external mic inputs are noisy with the 20dB pad engaged using a dynamic such as an RE-50, otherwise it's not bad.
Old November 2nd, 2008, 01:33 PM   #3
Thank you for your help
Old November 4th, 2008, 02:19 AM   #4
Thank you
Bob
Hi Bob,
IMHO, the PMD660 should be a good match with a consumer camera for interview work. If you're really concerned about the noise level of the preamp, contact Doug Oade to have the Marantz upgraded (or buy on directly from him):
OADE BROTHERS AUDIO Field Recording Experts, Sony, Tascam, Marantz, Fostex, Compact Flash recorders
But for most everyday situations, the PMD660 is fine considering it's only a 16 bit recorder. Still, the dynamic range is okay except for high-quality music productions, etc.
The Tapers Section - The Tapers Forum
Regards, Michael
Good luck, Michael
Michael Nistler is offline   Reply
