90 degree shoe adapter? at DVinfo.net
All Things Audio
Old September 10th, 2008, 03:59 PM   #1
Images: 32
Anyone help find a 90 degree shoe adapter? I'm not having any luck searching the internet. I'd like to mount a light on the top of the camcorder with a shockmount on the side. * Note: I'm not looking for a bracket, just hopefully a small cube that has shoe adapters on it.
Thanks in advance for any leads.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old September 11th, 2008, 08:51 AM   #2
I am not sure i understand exactly what you are looking for. Is it something like this? or am I way off?
The other solutions are either the Rycote Hot Shoe Extender, NRG Tri-Mount or the Cool Lux Dual Mount Bracket.
Perhaps if I have a better understanding of your requirements I can try to come up with other more appropriate solutions.
Marty Wein is offline   Reply With Quote
Old September 11th, 2008, 10:10 AM   #3
Images: 32
Something like this simple shoe adapter, but with an extra shoe mount on the left/right sides.
Old September 11th, 2008, 10:17 AM   #4
Images: 32
I see you mentioned this adapter, which might work with a couple of these shoe mounts. But I wish there was something that was just off the shelf.
Old September 11th, 2008, 01:08 PM   #5
I give up. The closest to this was once available by Mamiya but is no longer available.
Old September 11th, 2008, 01:47 PM   #6
Images: 32
Rats, that Mamiya adapter would have done it too! Thanks for trying Marty.
Old September 11th, 2008, 02:23 PM   #7
FWIW: While the NRG may be a bit large is is more flexible especially if you have larger pieces to mount like a shotgun in a shockmount etc. where the Mamiya just wouldn't cut it.
Old September 11th, 2008, 09:55 PM   #8
I was just looking up something like this the other day...
DM-Accessories - Shoe Mount Accessories
Kevin McRoberts is offline   Reply With Quote
Old September 11th, 2008, 10:21 PM   #9
Look for the J-Bar - it mounts in the mic slot and provides another hotshoe. I think there's a model with two hotshoes as well.
Abe Dolinger is offline   Reply With Quote
Old September 25th, 2008, 12:46 AM   #10
Images: 32
Thanks for all the help. The DM-Accessories AIS-Cube is what I was looking for. I'm hoping the cube will be an excellent way keep a low camera profile and still have the mic in a decent shockmount.
Old September 25th, 2008, 06:57 AM   #11
Are you sure you need the AIS-Cube and not the UNI-CUBE? The AIS can only be used with consumer Sony cameras that have the AIS shoe instead of a regular shoe.
Old September 25th, 2008, 09:23 AM   #12
Images: 32
Good point, I'll give them a call since, they also have a CMS-Cube for Canon camcorders and I'll be using this on an XH-A1.
Old September 25th, 2008, 10:22 AM   #13
For the Canon XH-A1 you would still use the UNI-CUBE since the XH-A1 sports a standard shoe and Not the Canon proprietary “Mini Advanced Shoe".
