Post-production Headphones at DVinfo.net
All Things Audio
Old September 9th, 2008, 06:40 PM   #1
I am looking for a good pair of headphones for post-production work. I need something that has good sound representation but cancels out outside noise. What headphones do you all use? I did a search but nothing came up, so if there is another post about headphones please let me know.
-Jeff
Jeff Kolada http://www.jeffkolada.com
Jeff Kolada is offline   Reply With Quote
Old September 9th, 2008, 10:39 PM   #2
I like the Sennheiser HD280 Pro headphones. They have good isolation, and have a reasonably flat frequency response.
Many will recommend the Sony MDR-7506. These are great for tracking and field recording, but they're a bit to "pretty" sounding for mixing.
Both models cost about $100, and will last you years and years, if not decades.
Jon Fairhurst
Old September 10th, 2008, 12:22 AM   #3
For what it's worth, I've used Beyer DT48s for years. Good exterior sound isolation.
I've wondered about the active noise cancelling headphones, such as Bose. Has anyone used these?
Nick Flowers is offline   Reply With Quote
Old September 10th, 2008, 02:43 AM   #4
In general, NR headphones have terrible bass response. Look at the specs before you buy.
Jon Fairhurst
Old September 10th, 2008, 03:32 AM   #5
-Jeff
Just FYI, though. While 'phones are fine for logging, evaluating shots for noise etc, and general editing, don't even think of trying to do a mix with them. For mixing you must use proper monitor speakers.
Old September 10th, 2008, 04:42 AM   #6
Steve speaks the truth. The biggest problems with mixing on headphones are 1) soft sounds come through loud and clear. Many of these sounds will be too soft in real life, 2) the L-R soundfield can't be evaluated well on headphones. For example, if L&R are out of phase, the sound cancels on speakers, but not on headphones, and 3) the bass response is hard to control in headphones.
Still, if headphones are your only option, there you go...
Jon Fairhurst
Old September 10th, 2008, 04:54 AM   #7
Get them while you can: Earthworks - Time Coherent Audio Reference Monitors
I will use headphones in post production, however mostly this is for alignment/delay purposes only. When I do multi-track stuff and have to do a two track mix-down, I use monitors, but will when I'm done check it with headphones. I usually also try to check a sample on stereos and car audio systems. Kind of let's me know if I got it right.
Wayne
Mics: KMR 82 i, NTG-1, MKH418S, MKH8040, SR77, QTC1, QTC40, SR30
Recorder: Zaxcom Deva 5.8 & MIX-12. Wireless: TRX900 stereo, Lectro 411
Wayne Brissette is offline   Reply With Quote
Old September 10th, 2008, 05:32 PM   #8
-Jeff
Hello Jeff,
Headphones for post? For editing, yes. Audio Technica ATH-M50. For mixing, no unless your viewer will only be listening on headphones. If not, then you need proper monitors placed properly.
Regards,
Ty Ford
Ty Ford is offline   Reply
