#31 | |
Re: Sennheiser SK100 Jack confusion
It is this grounding of the unused input that switches the inputs on and off. But - only on the G3 is it a *must* - you don't do it on the G2 and G1.
John Willett - Sound-Link ProAudio and Circle Sound Services President: Fédération Internationale des Chasseurs de Sons |
#32 |
Would shorting the tip to ground on the G1 and G2 be harmful - in as much as you are shorting out the mic power supply ?
#33 | |
Ring Sam Davison (Service Supervisor) or Andy Lillywhite (Chief Engineer) at Sennheiser UK and ask. They will know.
#34 |
I've ran SK100 G2's line level without the tip grounded.. no problems that I'm aware of.
Don't know about the G1 or even if it has a line level option. |
#35 |
The G1 does have the line level input , using ring/sleeve as on the later models .
The line input cables I made up work just fine with the tip left unconnected . |
#36 | |
For the G3 it *must* be grounded - the question was regarding a line cable wired for G3 being used with a G1 or G2. And I don't know the answer to this - you have to ask Sennheiser. The G1 is exactly the same as the G2 regarding wiring.
#37 |
I was stating my experience in response to Derek's post, "Would shorting the tip to ground on the G1 and G2 be harmful"
#38 | |
You did not actually answer the question about being harmful at all, you only said that you did not short it out on G1 and G2 systems.
#39 |
Old post, but, to use the SK100 G3/4 in the line level plug configuration, the tip should be tied to ground/shield. The G2 works either way..
