Mic Advice
Hi guys i need a good stero mic for a very loud, live event to used with my A1. My budget about $300. I was looking at thre rode stero video mic and AT stero but don't anything about those mic, so any help will be great. thx
That's about all you'll find for a stereo mic in that price range... good stereo mics typically run in the $1k+ range.
I use the Beyer MCE72, which costs around $370 at B&H. Clearly not in the same class as the $1000+ Audio Technica, but it suffices for me.
I posted a sample here last December, the links are still valid: http://www.dvinfo.net/conf/811843-post28.html I haven't used it at a very loud live event, but the steam train in that clip was pretty loud to me. My Sony V1 allows me to adjust the audio levels and set the input trim as well, presumably the A1 has similar. The Rode SVM is pretty good for the money, in my opinion, I have used it in the past. You could make or buy a lead to plug it into your XLR sockets on the camera if it doesn't have a 3.5mm mic socket already. Both mics are pretty good for general "atmospheric" noise. I'm not sure they'd be great at (say) picking out vocals over a cros or other music.
Irish Railway Videos on Youtube |
stereo mic
there is a gentleman selling a rode nt4 in the classified section of this forum for what appears to be a good price. also this is a decent stereo mic at that price point.
#5 |
The place i will filming is very loud joint. I see the SVM have a 10db pad. Do you guys think it is enough, I will be using A1.
#6 | |
If you're in a place that loud, be sure to wear hearing protection. If it's loud enough that it leaves your ears ringing, you're at the level that you're doing permanent damage. A lot of rock performers and stage crews have learned that the hard way. In-ear monitors that block external sound become a must.
Good news, Cousins! This week's chocolate ration is 15 grams! |
#7 |
I would start by qualifying if you really need a stereo mic. Most very loud live events are mixed MONO. The low frequencies that tend to dominate these events are non directional. Are you expecting to get a good stereo image in this invironment?
#8 | |
I would concern myself more with trying to pad (AKA, attenuate) the signal going into the camera/recording device. Wayne
Mics: KMR 82 i, NTG-1, MKH418S, MKH8040, SR77, QTC1, QTC40, SR30 Recorder: Zaxcom Deva 5.8 & MIX-12. Wireless: TRX900 stereo, Lectro 411 |
#9 | |
#10 |
Thanks for the great info guys. The A1 have 20db pad which i always use but i think 20db is a bit to much cuz sometimes sounds a bit muffled specially the bass. But i see the SVM have a 10db and iam hoping it would be enough and not distort.
#11 |
A pad should only reduce the level, it shouldn't make it sound muffled or change the frequency distribution.
