Getting a case for an old mic at DVinfo.net
All Things Audio
Old August 12th, 2008, 11:58 AM   #1
I got an old Sennheiser ME40, and the case sort of disintegrated, at least the foam insert part, and left a nice coating of blue crap on the mic. But anyway, is there a place I could get a new case for this that would fit it?
Talenos Productions at http://www.talenos.com
Matt Newcomb is offline   Reply With Quote
Old August 13th, 2008, 12:14 AM   #2
I can't help you, but if you solve it, please post a note here.
I have a matched pair of Sony C-37s that have the same problem. The original foam is disintegrating and I'd love to know where I could get replacement foam inserts.
Anyone?
Old August 13th, 2008, 08:28 AM   #3
pelican makes a number of small cases you could use. just get it with solid foam and cut it as needed. you can get a couple of mics into a small case with accessories. another option is PVC pipe. line the inside ends with some foam, glue one ONE end cap also with foam on the inside, and leave the other end loose. it may require sanding the loose end of the tube down a little to make the cap easy to remove. there are also some other commercially made mics tubes as well. just do a search for mic tube on DV info and it should turn up
Steve Oakley is offline   Reply
