Sound Devices 302 vs. Mixpre - Page 2 at DVinfo.net
All Things Audio
Old October 22nd, 2009, 10:53 AM   #16
Originally Posted by Corwin Garber View Post
If im gonna be working with only 2 microphones at a givin time, is there any reason why i should go Sound devices 302 over the mixpre? what are the differences?
Also, is it worth the mixer if i only have two tracks? Or should i plug the mics directly into a recorder?
Third, whats a solid recorder that can record 2 tracks of 24bit audio from xlr sources? around 1000?
--Corwin
I also like my tascam hd-p2, which I see oade bros also sells, although I have the unmodded version which has been great ($815 from B&H).. I can't compare that to the marantz for features since I don't know the marantz unit (that one looks nice too) but may be worth considering or comparing
Dave Stern is offline   Reply With Quote
Old October 22nd, 2009, 03:11 PM   #17
I have a mixpre and while i dont *regret* the purchase, I do have a lustful eye out for more channels (but perhaps more than 3?) Although I think the mixpre will be relegated to a boom mixer/unit to rent out to noobs.
The most obvious issue is that once i got more than 2 mics, I couldn't mix them.
A more everyday issue is that the mixpre ONLY outputs line level +4 audio over the xlrs. If you have a camera/recorder that only takes mic level inputs, then you gotta buy pads and put them in line and its just clumsy and not ideal.
A pro in favor of the mixpre is the size/weight. Its significantly smaller and lighter than the 302. In its petrol bag, two sennheiser g2 receivers basically take up the full width of the bag.
The limiters in the mixpre/302 are magic compared to most camera inputs. When running 1-man-army mode, i often get a rough level on the mixpre then forget about it unless something major changes. It handles the random shout like a champ.
All that said, if you buy a 302... chances are extremely slim that you'll regret it.
Andrew Dean is offline   Reply With Quote
Old October 23rd, 2009, 08:52 AM   #18
FYI - you can change the 302's ouput to mic level via the menu.
Steve House is offline   Reply
