FR-2 LE - independent XLR input control of LINE IN and PHANTOM? at DVinfo.net
All Things Audio
Old July 13th, 2008, 10:12 AM   #1
Images: 32
Looking at getting the FR-2 LE, but from the manual it looks like the LINE IN/MIC and PHANTOM functions are applied to both XLR inputs at the same time. Can anyone confirm one way or another? I'd like to be able to mix and match dynamic mics, condensor mics, and a line-in as needed.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old July 13th, 2008, 12:38 PM   #2
I don't have one so can't give a definitive answer but as I read the manual it looks like the mic inputs are on the XLR connector only and the line inputs are on the TS inputs only. Phantom is only sent to the XLR so its state would have no effect on the line input at all. Phantom gets its name from the fact that its particular wiring arrangment makes it invisible to a properly wired dynamic mics plugged into it. So I'd say you'd be safe using any combination of condensor mic, dynamic mic, or line level. If you have a condensor on one XLR and a dynamic on the other, turning on phantom to power the condensor will have no effect on the dynamic.
Old July 14th, 2008, 06:14 AM   #3
Yeah, you'll have no problem plugging a dynamic mic into a jack running phantom. About the only thing you can't plug into a phantom powered jack safely are some ribbon mics. They'll usually have their own power supplies. But I doubt you'll ever see a ribbon mic in audio for video!
David Beisner
Media Specialist, Bryan College, Dayton, TN -- www.bryan.edu
David Beisner is offline   Reply With Quote
Old July 14th, 2008, 06:25 AM   #4
Images: 32
Thank you that's all great information! You guys made it all make sense.
