Reading Timecode in Audition at DVinfo.net
All Things Audio
Old July 8th, 2008, 03:18 PM   #1
Hello,
I recorded video with timecode from my Canon xl2. I am able to see the timecode when I open the file in Adobe Premiere but do not see how to view the timecode using Adobe Audition. Is it possible to see the timecode in Audition (I have version 3)?
Any help is greatly appreciated!
Michelle
Michelle Levine is offline   Reply With Quote
Old July 9th, 2008, 07:54 PM   #2
As far as I know there are only three ways to read audio timecode (LTC) using a computer.
1. Import into AVID.
2. Import into Final Cut Pro using a tool from www.videotoolshed.com
3. Play the timecode track back into a slate. (I don't know if this counts, exactly.)
If you find a way to do it in Audition I would love to know! Best of luck.
Abe Dolinger is offline   Reply With Quote
Old July 10th, 2008, 09:41 AM   #3
Presumably the audio is captured with the video and then must be exported for use with Audition? The trick would be to export in a time tagged file format (such as BWF). Audition should then be able to read the time code tag and calculate the time of each sample in the file from it.
Old July 10th, 2008, 10:26 AM   #4
Originally Posted by Michelle Levine View Post
Hello,
Michelle
Haven't tried it but it occured to me that you might bring the clip into Premiere and burn-in a timecode window, then save the clip and import the result into Audition.
Steve House is offline   Reply
