Camera Hop Questions
Hi all.
I've been asked to do a cooking show and the director wants to go wireless to camera for the busy kitchen scene. I have a 302 mixer and lectro 195 and 200 systems. Up till now I've only used the them with lavs. Should I use a cable like this to go from the tape out?: http://www.trewaudio.com/store/produ...9&cat=0&page=1 Or should I use this from line out: http://www.trewaudio.com/store/produ...&cat=25&page=1 I'm also wondering about how the transmitter will take a line level signal? Should I be thinking about padding it down to mic level? Cheers from a somewhat spring-like Halifax Jon Goodman |
Wireless... that's the buzz word.
The Tape Out on 302 is -15 so will probably be fine, like a consumer line level. The Main XLR outs would work too, but you might have to pad them down in the 302 menu. I'd say, if you are using a backup recorder, what's the best way to hook that up to your 302, and the left over would go to hop. Other than that......it's up to you. |
lectro units are designed for this. there are two cables that are XLR -> TA5. one is line level, the other is mic level. basically its just a different connection of the hot on the TA5. get two Line Level XLR -> TA5's and you will be good sending line level out... or you could do mic level if you prefer as those cables will be more useful after the shoot to use on XLR mics.
you may prefer to power the transmitters on their own batteries instead of bag power due to problems with ground loops in the common power lines. lectro sells power isolators for this purpose. another thought - rent a zaxcom stereo setup that will also give you return audio AND records in the transmitter. |
You also want to add a wireless return from the camera to your headphones so you can hear a return on what the camera is receiving. Lectrosonics has some relatively inexpensive ones which many rental companies have. The output from the headphone jack will need a special cable most likely to make it work. The Zaxcom is a good idea but a big investment. I think a similar or lower cost but better investment is the Sound Devices 2 or 4 channel record harddrive so you can record direct from the mixer as back up maybe with iso's while sending the feed to the camera.
As for the cables from the mixer to the transmitter you should check out whether the line level cable is enough by itself or whether you need a pad to get the correct level for the transmitter or try the mic level cables as Steve suggested. |
#5 | |
If the director insists on a wireless send then you got to give it to him. Just explain the risks of NOT being able to clearly monitor what's going to tape. And it would be a good time to add a 24 bit recorder to your 302 bag for a backup and an upgrade at the same time. |
#6 | |
Wayne
Mics: KMR 82 i, NTG-1, MKH418S, MKH8040, SR77, QTC1, QTC40, SR30 Recorder: Zaxcom Deva 5.8 & MIX-12. Wireless: TRX900 stereo, Lectro 411 |
#7 |
Well just to give a different perspective I have done whole shows with wireless hops without back up in NY and managed to do them without the Zaxcom (although it did work pretty well for a documentary I used it on) using Lectrosonics but it is great if you can record a back up for peace of mind. Of course the 4K is spent one way or the other but the flexibility of Two systems sometimes outweighs the compactness of the Zaxcom.
#8 |
If I may folks: I've never heard the term "wireless hop". Would anyone care to take the time to explain?
Is this a director's audio feed from the audio tech's mixer or...
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
#9 |
the hop is from the mixer to the camera. audio OUT of the mixer, into transmitter(s), HOPS to the camera receivers and is recorded there. it replaces cables between the mixer and the camera.
#10 |
Thanks, Brian. Done that a couple hundred times but never knew that's what it was called. Appreciated.
#11 | |
Jon |
#12 |
no the cable is straight. the lectro rx has a padded pin in it. so the hot in the cable goes from the normal mic hot to the padded line level pin. go to lectro's site and they have the wiring for it. I'm surprised no one has made a switching cable.. but then again, why buy one universal cable when you can have 2 :/
#13 |
Thanks Steve. 2 mic level cables it is then. I suppose I could adjust the output gain to mic level in the menu.
Cheers Jon |
