how to capture audio the proper way at DVinfo.net
All Things Audio
Old May 29th, 2008, 03:30 PM   #1
majority of my projects are interviews
i have a senheiser system that i use the wireless mic to capture the audio. i shoot on the sony z1u and i for my xlr settings i to cut the audio at 6db and use the auto mode to capture the sound
problem i am facing is that for the most part when the person is talking the letter S is very sharp in recordings. and in compressions for web they start to sound like a wisp.
what settings should i use or what can i do to make this better?
thanks for your help
Dan Farzad is offline   Reply With Quote
Old May 29th, 2008, 03:33 PM   #2
What Sennheiser model are you using?
They have lots of wireless, G1, G2, lavaliere systems, and handheld mics.
The first thing I would check is the sensitivity adjustment on the transmitter.
If it is set to 0 dB, set it to -10 dB or even -20 dB for a test.
Dan Keaton
Augusta Georgia
Old May 29th, 2008, 06:10 PM   #3
I would not recommend using the auto mode.
Set it to manual, send the signal to both channels, but keep one channel 6db lower.
What lavalier mic are your using with your Sennheiser system? The stock ME2?
Hsien Yong is offline   Reply With Quote
Old May 29th, 2008, 09:30 PM   #4
Sounds like a placement issue. Maybe move the mic (I assume it's a lav) a little lower down? You might try putting a foam windscreen on it. In fact I'd try that first, assuming you don't have the mic right under the chin or something. There's a thread in here recently about turning an omni lav upside down to cut down on the silibance you describe, but I haven't tried it. There are also audio filters intended to reduce the problem in post.
Marco Leavitt is offline   Reply With Quote
Old May 30th, 2008, 05:20 AM   #5
I find the low to mid level Sennheiser lav's excessively harsh and sibilant (try saying THAT sentence without being sibilant), especially when placed too close to the speaker's mouth. Hopefully you have the option of applying the lav to a lapel or feeding thru a button up shirt so you can mount the mic a little lower (12" isn't as bad as you'd think in a reasonable quiet environment - I normally go for sternum level).
If you're stuck wiring someone wearing a t-shirt - GOOD LUCK! You'll need it. Popping a lav out the neck hole of a T-shirt is a universal disaster. Consider anything useable to be a blessing.
I've actually gone to using a boom pole for nearly all seated interviews these days for this reason. I use wireless lavs only for in-motion shots or when the client INSISTS.
Old May 30th, 2008, 08:48 AM   #6
I agree that a boom is better. In addition to everything else mentioned, are you recording in HDV? This means compressed audio as well. You may want to get a field audio recording that doesn't record compressed audio- that will make a big difference.
Mike
Mike Bisom is offline   Reply
