Olympus LS-10 -- weak line input?? at DVinfo.net
All Things Audio
Old May 21st, 2008, 08:57 PM   #1
Fred Retread
I just got my LS-10 today in time to record an event from the RCA "tape out" jacks on the sound board. I was only getting about -36 dB peaks with the recording level control turned all the way up. When I substituted my Sony HiMD recorder, the levels from the board were were fine. Does anyone with an LS-10 think I have a defective unit?
[Edit] I answered my own question. The LS-10 input is specified for -6dB. I put a known -6db (.5 volt) 1000Hz signal into it and got -12 dB on the level meter with the record level set mid range. As to why the board was putting out such a low "tape out" signal, I don't know. As to why the Sony HiMD recorder was fine with it, I don't know either, unless the board had a high output impedance and the LS-10 has a much lower input impedance than the HiMD
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply
