Will digital input give me balanced, interference free audio? at DVinfo.net
All Things Audio
Old May 7th, 2008, 04:43 AM   #1
Hi there,
Once again I´m asking for some obvious answers.
Would I get balanced and interference free audio when I use a mic pre amp with Analog to Digital converter (Core Sound Mic2496 V2) and input that digital (optical) signal to a recorder like Sony PCM D50? Will my sound still be distorted by incoming cellular/mobile phone signals etc? Or does it depend or vary on the inner circuitry of the recorder?
I want to use really clean preamps etc so this system is the best and cleanest in the sub $1500 area but I need to know it before I make another investment.
Thanks in advance,
T
Toenis Liivamaegi is offline   Reply With Quote
Old May 7th, 2008, 06:14 AM   #2
It would depend on where the interference is getting in. For esample, if it's your mic that's picking it up, it's already part of the signal before it ever gets to the A/D converter stages. As far as whether the digital signal is on a balanced line, that depends ... AES/EBU or AES3 digital is on a 110 ohm balanced cable while S/PDIF is on a 75ohm unbalanced cable. Regardless, because of the nature of digital signals, it's a far less important consideration there than it is for analog audio signals.
Steve House is offline   Reply
