Setting AF OUT on Sennheiser EW 100 G2
Hello.
When reading the EW 100 G2 manual I see described the range of AF OUT settings for line or mic level (line o to +12; mic -30 to -6dB) My question is how does one choose a setting within these ranges. All the manual says in this regard is: "Adapt the level of the audio output (AF OUT) to the input of the connected unit." I don't really know what that means. All I notice is that when I set the AF OUT at a higher number I get a hotter reading on the mixer's meter (SD 302), which I then compensate for by adjusting the gain. In short, it seems as AF OUT goes up, gain goes down; as AF OUT goes down gain goes up. This all leaves me wondering what the optimal setting(s) are and what makes them that. Thanks. John |
#2 | |
The same idea applies if you want to use mic level settings. After setting the 302 input and the receiver accordingly, adjust the receiver output setting so it produces a 0VU meter reading on the 302 with the mixer's coarse gain and fader set to their midpoints and you're sending speech that's deflecting the transmitter/receiver AF meter to full scale without overloading.
Good news, Cousins! This week's chocolate ration is 15 grams! |
