New Marantz Professional Field Recorder at DVinfo.net
All Things Audio
Old July 6th, 2003, 04:17 PM   #1
Marantz introduced a new professional solid-state recorder PMD-670, which I think will be a hot piece for the documentary and the ENG/EFP industry. It has all the professional features you need, like Dual phantom power, compressed or uncompressed (DAT quality) recording, long battery life, direct connection to a computer plus lots of other great features.
The recorder uses Compact flash type cards and is compatible with the IBM Microdrive that can handle up to gig (if not more). However, after doing some research, I think that the best way to use it would be to buy only a 640MB card along with a portable Compact Flash to CD recorder that is battery operated and does NOT Require a computer, so you can transfer your files to a CD on the fly, empty the card and continue recording. A Compact Flash to CD recorder is only about $299
The PMD-670 Lists for $899
http://www.marantzpro.com/Products/PMD670.html
http://www.marantz.com/p_product.cfm?id=2418&cont=e&line=prd&cat=pro
Marty Wein is offline   Reply With Quote
Old July 6th, 2003, 07:36 PM   #2
Moderator
Yes these are cool, played with them at InfoCom 2003. I'll take a couple please.
Originally posted June 25, 2003:
http://www.dvinfo.net/conf/showthrea...solid+state+CF
Check these two solid state CF recorders from Marantz:
http://www.marantzpro.com/Products/PMD680.html
http://www.marantzpro.com/Products/PMD690.html
Pretty cool and under $1000 I believe.
And, from Denon:
http://www.usa.denon.com/catalog/ph...F20R%2Ejpg&c=47
http://www.usa.denon.com/catalog/pdfs/DNF20RLIT.pdf
Nice.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old July 6th, 2003, 09:53 PM   #3
What was originally posted on Jun-25 where the old model's PMD-680/690. The PMD-680 "under a $1000" did not have Stereo Recording.
The NEW model also supports many other file formats, the AA batteries will last almost a days worth of shooting and some other differences.
Therefore I do believe that this model offers greater versatility for people who are looking for another source for there audio recording and/or are doing NLE.
While MD is a cost effective choice, most MD recorders in the lower price range (under a $1000) do not have decent MIC PRE's or XLR's and also do not offer "digital out" which means that if you want to transfer the file to a computer, it has to be converted from Digital to Analog and back to Digital.
Old July 7th, 2003, 12:42 AM   #4
The 670 is being advertised as low as $698US
Bryan Beasleigh is offline   Reply With Quote
Old July 7th, 2003, 02:21 AM   #5
Cost aside, which is better you think? This Marantz recorder, the HHB Mini Disc recorder, or a Tascam DAT?
Christopher Go is offline   Reply With Quote
Old July 7th, 2003, 05:00 AM   #6
As far as audio quality, I don't think there will be a different between DAT and the new Marantz PMD 670, and it's definitely better then MD. However, the Marantz will have to prove itself as being a reliable unit in order for it to take over the DAT market.
As far as the quality of the Mic Pre's, Marantz is not new to this industry, in fact their cassette recorders are industry standard, and while it may not be the Nagra quality I believe that it will be as good as the Tascam +/-
The only downside to the Marantz "so far", is that the media is still a little too expansive. This is the reason why in my original post I wrote about the CD backup. Since on a stand-alone CD recorder you can backup up to a 640MB card, CD's are cheap and quite reliable.
If you are carrying a laptop, you can use even higher capacity CF cards since you can backup alot more at once.
I would like to hear all arguments.
Old July 7th, 2003, 09:15 PM   #7
Thanks for posting I was getting ready to order a HHB minidisc recorder out of flustration with consumer units. Now I think I will save $600 bucks and order this one.
One question that I have is if ATRAC is better or worst than the MP2 codec that they offer.I would love to use PCM to record but man it really kills the Flash card according to the list of times that Marantz posted. But then again for weddings is 48kHz PCM really neccasry? Does anyone think there would be something to gain by using uncompressed audio? I personally like the idea of poping in a 512meg card and recording the entire DJ directly from the line out of his console. Changing the Disc every hour is certainly a big PIA.
Scott
Scott Osborne
Infinite Video Productions
Scott Osborne is offline   Reply With Quote
Old July 8th, 2003, 04:56 AM   #8
First you should check what file formats your editing software supports.
ATRAC at the High Quality setting is better then MP2, But MP3 At the higher rate is probably better the ATRAC. Unless you have a real trained ear you will not hear the difference between DAT and MP3 or ATRAC (if recorded at the higher bitrate).
For what you are doing, I would record in MP3 at 256kbps and you will get over 4 hours of high quality sound on a 512mb card.
You can get up to 7 hrs if you select 160kbps and still get excellent quality sound.
If you want to know more about ATRAC vs. MP3 please check out http://www.minidisc.org/
BTW: I just checked and I found that Marantz posted a new .pdf on their site, which has a little more specs.
http://www.marantzpro.com/Products/docs/PMD670lit.pdf
Old July 8th, 2003, 08:18 AM   #9
I do all of my audio editing in Steinberg Cubase SX so I can support any file format.
Forgive my if I am wrong but isnt MP3 Mpeg1 layer 3. And isnt MP2 Mpeg2. If this ia true wouldnt Mp2 at 384 bitrate provide the best sound quality.
As far as quality goes I am not so worried about myself. I usually can tell the difference between a Mp3 and a 48 kHz 16 or 20 bit PCM recording. I am worried about clients. After all there paying for it.
I am suprised that Marantz isnt offering a 24/96 recording mode for it. It would make a nice little "mini studio" for recording away from the house.
Scott Osborne
Old July 8th, 2003, 05:50 PM   #10
Scott
MP2 vs MP3....
I found a couple of links that you may find interesting.
http://www.wikipedia.org/wiki/MP3
http://www.dvdrhelp.com/forum/archive/t154398.html
http://www.mp3clubpro.com/english/techniques_en.html
http://www.solorb.com/dat-heads/digests/V5.600/D611#Msg12
Old July 8th, 2003, 06:29 PM   #11
That was quite fascinating. took some of the "sorcery" out of audio codecs. However I think that I have more questions now than before and very few of them have clear defined answers. Mainly because like so many things in the audio world this is all subjective to the listners ear. As I stated earlier Mpeg1 Layer 2 seems to be the best but only at extreme high bitrates such as 320 or 384. But then again is there a large enough difference between that and Mpeg1 Layer 3s ' "sweet spot" 128-196 kbps. Would there be a disearnable seperation in the audio quality at these settings. I guess the only person that can answer that question is myself. So many things in audio seem to be based on personal tastes.
My question about the clients seems to be answered. As one article stated. Broadcast radio stations have been using MP3s for sometime now. I rarely hear the layman complaining about the acoustical dynamics of there radio signal.
Thanks for the wonderful links,
Scott Osborne
Old July 11th, 2003, 04:18 AM   #12
Anyone purchase one yet? Any recommendations on where to obtain media for it?
Old July 11th, 2003, 09:41 AM   #13
It utilizes standard Compact Flash Cards/Media that you can find in any computer and/or photo store.
Old July 11th, 2003, 09:22 PM   #14
Thanks, Marty - I also meant to add which brands to look out for or avoid for this kind of media. I have no experience with them. I was wondering if there was any place that sold them at a good price too.
Old July 12th, 2003, 09:05 PM   #15
Just to name a few, Sandisk and Lexar I would feel comfortable with. I am sure that there are other good brands out there.
