Audio Technica w/Sennheiser at DVinfo.net
All Things Audio
Old February 7th, 2008, 07:03 PM   #1
I have two Audio Technica Pro88w, the ones with two selectable frequencies.
When using them together, I obviously set one to frequency A, the other to frequency B.
I'm thinking of buying or renting another one for a scene with 3 actors, so each actor is wired separately.
I'm thinking of getting the Sennheiser, that seems to be the one everyone likes. I just need to make sure (I guess) the Sennheiser doesn't interefere with the frequencies the Audio Technica uses. The Sennheiser is very selectable right? I should be able to look up the frequency the ATs are using, and make sure the Sennheiser is using something different.
Just asking for a reality check - that makes sense, and ought to work?
thanks.
Dennis Stevens is offline   Reply With Quote
Old February 7th, 2008, 08:12 PM   #2
no problem
The Audio Technica works on VHF and the Sennheiser works on UHF. Should be no problem. The only thing that might be a problem, is that the Sennheiser might be cleaner.
Walter R. Scott is offline   Reply
