Wireless, mixer and computer: Will this work?
I need to narrate some material for a short video and would like to go directly into my mac. I have a wireless set up with mics and an SD 302.
Would I be able to run the wireless into the SD 302 and then run "mic" level out to the computer? Would that make sense? Thanks Bob |
If you have a line in on the pc then yes. Might be a bit noisy depends. Better of with a dedicated sound card. Try it and tell us..
DVCreators.Net
http://www.mxlmics.com/condenser_mic...te/micMate.htm
MXL Mic Mate would work. Small, easy, inexpensive XLR to USB. You'll need a USB cable (not included) |
Thanks. I'm going to have to wing it, as my deadline got pushed up by half a day. I'll let you know what I discover.
#5 |
why not go hardware ? if its audio only it'll be cleaner.
#6 |
Agreed that would be best. I always forget that the mac requires powered mics with mini connectors. I rarely need to narrate. Unfortunately, the project was given to me at very last minute and there won't be time to hit the store in the morning before it is needed.
So what hardware do you reccommend for narration work? I guess I basically need something to go from XLR to firewire or usb. Are the USB kits marketed toward podcasting suitable for narrating into Final Cut? Thanks again |
#7 |
there are plenty of 2 channel USB or FW audio adapters to be had at the local music store. there are also USB mics, but I would stick with the USB/FW converters. if you can run hardware, make sure the adaptor can supply 48V phantom power ( which means most of the cheapest ones are out ), or battery power the mics. if you have the 302, you can use its phantom power for the mics, but be sure to select its outputs to match the USB/FW adaptors as line into mic level is never good.
#8 |
There is a thread nearby that covers many, many interfaces.
I will mention E-mu since I have two of their high end audio interfaces and I am very happy with them. (I have the 1812m -- discontinued -- and the 1616m.) For what you want the USB 0404 would be great I think: http://www.emu.com/products/product....&product=15185 It has two channels, line or mic input, 24 bit capable, very good mic preamps, limiters, phantom power, Mac OS X compatability, S/PDIF, TOSLINK, MIDI etc. etc. Here is a review in Sound on Sound: http://www.emu.com/news/reviews/file...OS_Jan2007.pdf This has a street price of $160-$180. There is also the 0202 that is less expensive with different features. I think the e-mu or another brand interface makes more sense than the USB mics and other podcast type gear. The 0404 can be used with virtually any input on any computer just by plugging into the USB. |
#9 |
It can be done. I took my Senn wireless and plugged it into the back of the Mac. Required really cranking the RF out to get signal on the FC voice over window but it worked in an emergency.
Now onto a better solution! |
