Sound levels issue in camera at DVinfo.net
All Things Audio
Old October 19th, 2007, 08:12 PM   #1
Hi all,
Let's see if I can properly explain this. I'm using a Canon XH-A1 with a SD-302 mixer. I have a wireless receiver plugged into input 1 (mic level, DYN), then coming out of the mixer to the camera (ch 1). I then send tone to the camera and adjust the camera levels to -20db. During recording I watch the mixer levels and ensure they are normal. The resulting audio on the camera is completely blown out (too high), even though the levels never go above -20 on the camera or the mixer. The levels on the camera also seem to be locked absolutely at -20 (bars never go above). Not sure what's going on. Any ideas are greatly appreciated.
Michael
ps. should also mention that I've recorded audio on the the other output to a flash recorder and it came out fine.
Michael Foo is offline   Reply With Quote
Old October 19th, 2007, 08:56 PM   #2
I'm guessing you're setting the 302 to line level and the camera is set to mic level input.
You can actually throw line level tone to a mic input and set level. If you listen in the headset, you can hear the distortion hair around the tone compared to when you set the camera to line level input and hear normal sounding (no hair) tone.
Welcome to the wonderful world of pro audio. :)
Regards,
Ty Ford
Old October 19th, 2007, 09:24 PM   #3
distortion
Do you have the output of the wireless receiver set up to out put line and the input of the mixer set up to receive Mic? that is what it sounds like its the problem . the distortion is happening between the receiver and the mixer rather than the mixer and cam, which explains distortion with meters showing a normal level. "gain staging" thats the key, research it, it is way too complicated to go into here. but it is critical, not to mention that when you master it you get the quietest silence you can achieve out of your gear.
Gerry Gallegos is offline   Reply With Quote
Old October 19th, 2007, 11:32 PM   #4
Ty/Gerry, thank you for your replies. You were absolutely correct. I feel pretty dumb now. The output jacks on the SD-302 are configured as Line by default. I set the XLRs on the camera to match the signal input. Problem solved.
Thanks again.
Old October 20th, 2007, 05:10 AM   #5
Michael,
Hey! At least you figured it out before you got out there and recorded without listening and botched the job.
You win big time in my book because you listened, learned, got it and moved on!
You'd be amazed at the number of people I hear from who blow a whole shoot because they didn't listen during shooting.
Regards,
Ty Ford
Ty Ford is offline   Reply
