#46 | |
Regards, Ty Ford |
#47 | |
The HDV audio is inferior to the DV audio on the same camera (like the XHA1) because the audio signal is compressed into and with the Video stream into the GOP while the DV audio is recorded seperately from the video stream onto the tape. Not sure if they could have chosen less compression for the audio and still fit it in the stream although I would have thought so. There apparently was space on the tape for simultaneous DV quality audio recording with the HDV Video but it was always out of sync by something close to the length of the GOP so no manufacturer seemed to want to deal with it. |
#48 |
Dan,
Yes, I had surmised that the mpeg audio was probably due to the latency problems; video encoding taking longer than PCM audio. So they needed to slow down the audio so it would sync with the video. Regards, Ty Ford |
#49 |
Ty,
Yes that was what I was told about the Mpeg audio as well but they still had room on the tape for the out of sync PCM signal to be recorded which could have been dealt with in post. A little tricky perhaps but might have been worth it. For example I am not sure if anyone would be able to access the PCM audio on firewire at the same time as the Mpeg. Might have taken more than a little engineering. HDV was an unusual advancement over DV in that a higher quality video image over the previous spec was married to a lower quality audio signal from the previous spec when it probably didn't have to be the only option due to physical constraints of data rate recording limitations. Certainly not much we can do about it now but it is good to know that newer is not always better quality in all respects or better designed. |
