Can I use my Rode NT1a on a boom at DVinfo.net
All Things Audio
Old September 13th, 2007, 05:56 AM   #1
Hello,
Do you think I could get away with using my Rode NT1a on a boom in an overhead indoor interview situation?
I appreciate that this might not be the most suitable mic but it is the only one I have at the moment.
Alex
Alex Wren is offline   Reply With Quote
Old September 13th, 2007, 12:59 PM   #2
That would work..... but it's a bit heavy!
Brooks Harrington is offline   Reply With Quote
Old September 13th, 2007, 01:53 PM   #3
Don't worry I have got that bit sorted. I have a lighting boom, counterweight and shockmount. I have not had a chance to try it yet so I thought I would see if anybody else had done it or knew if the mic would be ok for this.
Alex
Old September 13th, 2007, 03:37 PM   #4
The NT-1a is not a hypercardioid.
You will hear a lot more room than you want. The nastier your room, the worse the sound.
Relative to a good boom mic, you will be disappointed.
Regards,
Ty Ford
Old September 14th, 2007, 01:33 AM   #5
Does not hurt to try. I have used NT-1A to record a tight group of people, mic hanging from above about 0.5 m distance from the talents. Worked fine, better sound than from Oktava 012 hyper I had next to it. It was a hard walled photo studio about 15*9*6 meters in size.
Petri Kaipiainen is offline   Reply With Quote
Old September 14th, 2007, 05:58 AM   #6
You're actually going to hold a boom with an NT1-a (or any studio condenser)? Holding it with your arms?
Having someone actually operate a boom makes a big difference. It's not unusual to move a boom even with only one person.
Maybe because a cardioid is wider than a hyper and would cover the group better, but at the expense of the sound of the room. Please let us hear that audio.
I don't want to have the idea that sticking a mic on a static boom on a regular basis is a good operating practice.
Regards,
Ty Ford
Old September 15th, 2007, 05:54 PM   #7
Given the choice I think I'd rather stick a SM57/8 up there. The added sensitivity of the NT1a will just pick up all the stuff you don't want... ie room ambiance. I've acheived more reach than expected with a good old 58 in the right situation. Being less sensitive they don't hear as much indirect (reflected) sound if you ask me. - Well maybe, when you want to try the Rode on a boom then I guess anything's an option worth trying!
Stop Press: just tried it and I think I'm right, but not by far!
Good Luck
Jimmy Tuffrey is offline   Reply
