Budget / mid level 5.1 monitoring? at DVinfo.net
All Things Audio
Old September 11th, 2007, 03:51 AM   #1
Hi All,
I currently have a high end PC edit workstation (2 x quad Xenon CPU's) with a Matrox Axio HD edit card. I'd like to (rarely) do some 5.1 mixing within premiere pro 2 (soon to be CS3) and also use the 5.1/7.1 speaker setup for other tasks (including a bit of gaming from another desktop PC.
I'm after recommendations for the best type of kit and setup to go for.
My edit PC and Axio is connected via a Behringer Xenyx2442FX mixer and out to a pair of Genelec 2029AL amplified monitors for stereo mixing.
I also had a cheapy set of Creative labs Gigaworks S750 speakers and 7.1 amp which were surprisingly OK for general PC DVD/gaming playback. Unfortunately these have just died after about 4 years of service.
So, I need to replace them but though it may be best to combine all my needs into one set of speakers/amp.
I don't want to spend thousands but could afford a low end budget of say £700-800. Could I incorporate the Genelecs or is it not worth it? Should I be looking at a good consumer 7.1 amp and speakers? Can you get pro level speakers at the cheaper end of the market?
Paul.
Paul Gale is offline   Reply With Quote
Old September 11th, 2007, 10:05 AM   #2
Going up the range a bit - I was just looking at a 5.1 set of JBL LSR4328P's.
Would you recommend these as suitable?
Old September 11th, 2007, 12:08 PM   #3
Paul,
look at this thread:
http://www.dvinfo.net/conf/showthrea...=JBL+4328P+LSR
There are some opinions about the JBL monitors voiced.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old September 11th, 2007, 12:56 PM   #4
Thanks Martin - yes I did see that post which got me onto the JBL's.
Cheers.
