Canon XH-A1 + Mackie 1202? at DVinfo.net
All Things Audio
Old September 7th, 2007, 09:10 AM   #1
I would like to use this combination of camcorder and mixer. I assumed I'd use the XLR line-in option on the Canon, but so far my best results have come from using the Canon's XLR mic-level input and the attenuated mic output from the mixer. I'm probably making a simple mistake, but perhaps someone here can help me understand if the two devices are compatible to begin with.
From the Canon specs under the XLR input I get:
6 dBV (Auto mode)/10 kohms (LINE/MIC switch set to LINE)
-59.d dBV (Auto mode)/600 ohms (LINE/MIC switch set to MIC)
From the Mackie specs for "Main Output" I get:
"Using balanced XLR-3-M-type connectors, maximun output of +28dBu, including 1 Main Output Level switch to provide 30dB attenuation." and "Output impedance: Tape Out, 1.1 kohms; all other outputs, 120 ohms."
The "30dB attenuation" refers to the switch which provides the mic-level output from the mixer, I believe.
I hope this is enough information. Thanks.
Jim Schweer is offline   Reply
