AT 1800 - two plug-in better than bodypack?
I'm going to buy the AT 1800 but tell me if there's a flaw in my logic. I think it'd be more versatile to get two plug-in transmitter. There are times when I need lav and handheld. Should I need a lav, I can get a regular XLR lav and pouches with belt clip for the tranmitters. Whereas if I had the bodypack, I can't convert that to a handheld without another wire. Would I risk any loss in quality by doing this? And can anyone recommend good lavs for this? Thanks!
The plugon doesn't have the range of the body mic.
Regards, Ty Ford |
#3 | |
also it bulky to use that way , good only when you need it as back up if you intend to use handhelds , buy the battplugs and if it lavs -regular |
Thanks Ty. Any idea what's the difference in range? The specs list 300 feet. I probably won't need more than 100 tops. It's really more about convenience.
I guess I'm more concern about connectivity. The phantom power is only 12V, it seems most XLR lavs requires a range that exceeds that. I'm looking at the countryman EMW, specs said it required 1.5-24V but the same mic except with 4 pin connectors is listed at B&H as compatible with with Audio Technica. Should I expect any problem if I use this mic? Has anyone tried any XLR lavs that worked well with at AT plug-on? Oleg, What is a bias converter? Is that like an amp I can buy? I did a quick search on that and found nothing, do you have a link to one? |
