Wireless Lav Mic + Canon XL1 at DVinfo.net
All Things Audio
Old September 3rd, 2007, 02:16 AM   #1
Hi all,
Just wondering if a wireless lav mic setup will be directly compatible with an XL1? Are the outputs on lav mics normally mini stereo jack or XLR?
Dave Robinson is offline   Reply With Quote
Old September 3rd, 2007, 06:41 AM   #2
Originally Posted by Dave Robinson View Post
Hi all,
The output port on almost all wireless setups are 1/8" mini stereo. Just plug into the mike input socket. If you get a MA-200, you can use XLR adapters, mini plug out of the receiver and then the XLR plugs into the MA-200.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old September 3rd, 2007, 06:55 AM   #3
Brilliant.
Thanks very much.
Dave
Old September 3rd, 2007, 06:56 AM   #4
Hi all,
... Are the outputs on lav mics normally mini stereo jack or XLR?
Not to correct Mike but it really depends on the specific make and model receiver you are looking at. For instance, the popular Sennheiser G2 has unbalanced miniplug and unbalanced mini-to-XLR output cables, the new Audio Technica AT1800s are balanced XLR while their older VHF models are mini, Lectro has some receivers that are mini and others that are XLR. You're just going to have to check each one as you narrow down your choices.
Are you speaking of just wireless lavs or are you also asking about hard-wired lavs?
Old September 4th, 2007, 07:26 AM   #5
Well I need to do some shooting for a commercial and tried using a shotgun and boom setup which worked ok, however I was thinking seeing as I dont need any environmental interaction I thought a lav would be the better option. I may be wrong?
It would need to be wireless though.
Old September 4th, 2007, 08:04 AM   #6
While Steve is basically correct, that it depends on the model you buy, the common senders used with a Lav has a mini-plug input.
The model 1800s he mentions come in two basic kits at B&H, ATW-1821 and the ATW-1822 kit. One has two XLR plug senders, but these are generally used with shotgun type mikes, i.e. wireless boom mikes. The other set comes with body-pack transmitters, the ones that are generally used on persons miked with Lavs. These use mini-plug inputs/outputs.
I have wireless 5 systems right now, Sennhieser and Sony, and I used to have an Azden. All have/had mini-plug input/outputs. BUT, I have a separate or additional shotgun sender for the Sennheiser G2 outfit, which has the XLR out jack. These are very handy!
I got my G2 outfit with both shotgun sender and bodypack sender from Guy Cochran at the DVeStore, one of the great sponsors of this forum. He has the Sennhieser G2 kit with both the shotgun and bodypack sender for only $599.00 and that is a great outfit.
Check it out at http://dvcreators.net/sennheiser-mics. It's the second kit listed on the page.
Anyway, I hope this makes it clearer for you.
Mike
Old September 4th, 2007, 08:37 AM   #7
LOL I think Mike and I are demonstrating one of the basic problems of internet communication. It appears he's thinking mainly of the mic to transmitter connections while I'm thinking mainly of the receiver to camera / mixer / recorder connections.
Old September 4th, 2007, 08:45 AM   #8
I think I got that from your question about wired or wireless lavs! Hey, we are having fun and Dave is getting pretty good info. :)
Cheers---Mike
Old September 4th, 2007, 09:57 AM   #9
You betcha!
Old September 4th, 2007, 04:40 PM   #10
Um, check me on this Steve, but aren't the receiver outputs on the 1800 three pin mini xlr?
Ty
Old September 4th, 2007, 05:14 PM   #11
Ty
Yep, you're absolutely right. And according to the A/T site each receiver comes with one or two TA3 to XLR-M cables (depending on receiver model) as standard equipment in the kit. So with the standard package it's compatible with conventional balanced XLR inputs. Sorry if I wasn't clear.
Old September 4th, 2007, 05:16 PM   #12
The receiver outputs are 3pin mini XLR, and the package comes with mini to standard XLR adapters.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old September 4th, 2007, 05:42 PM   #13
Is there any functional difference between the two?
M
Old September 4th, 2007, 05:53 PM   #14
On a budget with an XL1, what would you choose?
M
