When do I need to get a dead cat?
Hi:
I am looking into order a mic, camera mountable, so I was wandering what else I might get: A windscreen and a dead cat maybe. Is there a thumb rule that can guide me just when do I need a dead cat? Say windspeed > XX mph? Thanks, Erik |
I just recently got a dead cat for my mic (Rode Videomic), so my experience with the dead cat is very limited.
From my brief testing I would say you need the dead cat with any wind stronger than a light breeze. (say around 7-10 mph or stronger, maybe even with less wind.) |
A Rode dead cat will only give you minimal wind diffusion. Just leave it on all the time. If it's really windy, you'll know it.
That is what I intend to do. But even with only the standard windprotection for the Rode Videomic, I have successfully used it in wind up to about 5mph without any (or at least very little) wind noice.
#5 |
anything stronger than a light breeze? So, is a standard windscreen any good for anything then?
Secondly, does the dead cat make sound furry - say in studio conditions? |
#6 |
Hi Eric.......
In studio conditions one would hope there would be no wind to worry about, so no need for any covering whatsoever.
The "dead cat" has some appreciable "top cut" when fitted over a "blimp", but would only be used when the wind is really "going for it" and even then not something the average "Joe in the street" would notice, not a worry. If the weather is fierce, the "Blimp/ Cat" combination can't be beat. It is, however, a necessary evil if the elements are so inclined. CS |
#7 |
The standard windscreen helps prevent exhalations from reaching the mic in close micing scenarios and "wind noise" caused by moving the mic itself through otherwise still air.
Good news, Cousins! This week's chocolate ration is 15 grams! |
#8 |
Yes.....rule of thumb..... when mic is on a boompole (moving mic), it needs to have some kind of windscreen, even indoors on a set.
In studio stationary on a mic stand, it's not needed. |
#9 | |
thanks in advance |
#10 |
Hows this for a wacky answer to an audio question.
You need protection from the sound of wind... when you can HEAR the sound of the wind. This is a great example of why you need functional and professional quality headphones EVERY TIME YOU SHOOT SOUND. Period. Nobody would EVER think to shoot video after turning off ALL the monitors and viewfinders so that you couldn't see your framing and the picture you're shooting. So it baffles me that people would consider shooting sound without LISTENING to the sound they're recording. So I guess the fundamental answer to this is what I noted above. You need wind protection when you're in a situation where you can hear the wind - and you don't need it in any situation where you can't. The REAL key is to train yourself (or someone!) to carefully listen EVERY SINGLE TIME you're shooting sound. No excuses. No exceptions. That's the way to solve this problem before it becomes a problem. FWIW. |
#11 | |
If I could get an idea of how weak winds can be and still be noticeable then that gives me a guide as to whether or not to buy now or get something else I might find more use of. |
#12 |
The only real answer is to get a good set of closed-back headphones and listen while recording. Even if you could say that a furry is required when the winds exceed, say, 5 knots (just making up the number), that is going to vary depending on whether the wind is blowing along the axis of the mic from front to back, back to front, or side to side.
#13 | |
Then make Sony MDR7506 headphones your next purchase. Wear them. When you hear wind, do something to abate it. At some point, a dead cat will give out and you will need more. Regards, Ty Ford |
#14 |
Hi Stu...........
Got myself the full catastrophe when I tooled up with my Sennheiser ME64,66,67 mics.
Rycote "Softies" for each for everyday use and full Rycote "Windjammer" blimps, con blocks and mortified moggies for when conditions are, er, less than ideal. As part of the package went for a Rycote CCA for the camera bracket and a shed load of pistol grips and assorted other mounts to boot. Cost an absolute fortune, and take up one heck of a lot of space, and are, er, interesting to assemble if I need to tool all three up but, boy, are they worth every cent! (We do get some very inclement weather here in the South Island) CS |
#15 |
