Firmware v4.1 Timelapse question at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old November 22nd, 2012, 06:38 AM   #1
Maybe Jon can answer this if he scans this board.
v4.1 Timelapse is another good addition. One small issue is when the timelapse is on it does not seem to be displayed in the status menu. Therefore the timelapse menu could be left on by mistake and you can only tell if you go through your menu options.
Am I missing a display somewhere?
Thanks.
Nick G. Smith is offline   Reply With Quote
Old November 26th, 2012, 12:03 PM   #2
AJA
Re: Firmware v4.1 Timelapse question
Nick S. - The 9.0 Interval Record parameter indicates whether the timelapse recording feature is enabled or not; there is not an additional indication. With regards to your comment about leaving a setting configured by mistake: as a general rule, we would always suggest reviewing the Ki Pro settings prior to use. Using the Factory Reset parameter is also a nice way to return everything to the default settings prior to your configuration of the device. As a shortcut for configuring your settings, you can also create and use Presets to recall your most commonly used configurations.
I hope this information is helpful,
Jon Thorn
Senior Product Manager
AJA Video Systems, Inc.
Jon Thorn is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
