4 Audio Channels Sony F3/Ki Pro Mini at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old June 24th, 2012, 09:43 AM   #1
Hello
i think the title says it all. for my next project i have to record 4 seperat audiochannels and would prefere to record them on the ki pro mini. (no external sound recorder).
i'll use a stereo micro and 2 lavalier microphones along with the sony f3 and ki pro mini. i understand that the ki pro does accept more than two audio channels via SDI (embedded) so i wonder if there is a solution to add 2 audio channels to the SDI signal. or might there be an other way?
thanks and greetings from switzerland
Michael
Michael Hauser is offline   Reply With Quote
Old June 27th, 2012, 09:02 PM   #2
Re: 4 Audio Channels Sony F3/Ki Pro Mini
Micheal, I think you will need to use an SDI audio embedder such as this:
http://www.bhphotovideo.com/c/product/747217-REG/AJA_HD_SD_4_Ch_Analog_Audio.html
Will Salley is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
